Pauls130
Post: # 12927Post
May 1st, 2016, 5:20 pm
One of mine failed . They have a large nylon "nut" at the top . I dismantled it and investigated repairs . Happijack would not supply me and remaking wasn't cost effective. I bought a new one from Niche Northstar dealer 01507 327172 . I think £270.
I prefer not to use the motors too much , it is too easy to go too far . Doing by hand you can feel when they are struggling .
- Site Admin
Post: # 12928Post
May 1st, 2016, 6:00 pm
"To be more specific the head of the screw tread in the jack has sheared. Looks like the mounting plate inside the jack is bar tack welded on assembly so repair doesn't seem possible"
Post: # 12930Post
May 1st, 2016, 6:39 pm
You can get it apart by relieving the staking at the top of the leg . It will come apart , but it is a fight , but I don't know how that will help you unless you think it would weld back on. Be careful , there is a square plate around the threaded bar at some pint which is supposed to jam the leg if it fails .I can't remember where it goes and its easy to not see .
- Site Admin
Post: # 12960Post
May 2nd, 2016, 1:46 pm
"so some further dismantling this morning. The top pin is a separate part"
digger.walker
Post: # 13514Post
digger.walker
June 6th, 2016, 4:35 pm
Paul, you might find Niche Marketing ( if they still call themselves that) might be of assistance. I had an overextended Jack and the engineer was able to relocate the thread after a while.
- Site Admin
Post: # 16009Post
November 16th, 2016, 9:21 pm
Paul can you tell me what the upshot was on this leg in the end?
