What Tub Liner and other stuff?
Madmountainman
Post: # 12466Post Madmountainman
April 9th, 2016, 11:55 am
I don't want to be overly precious with my pickup, but would like to look after it as much as possible, so i'm looking at tub liners.
What's your experience of them and your recommendation? I do quite fancy the bedrug lining, but will it be camper proof? I've also seen plastic liners used in conjunction with a carpet liner that slips in when you wish to use it. Any thoughts?
I'm also pricing up Dinitrol wax rust proofing treatment for the underneath, which looks to be a good idea, given the amount of metalwork that'll go rusty. Circa £500 seems to be the ball park figure, with 3 days to get the job done professionally.
Also, wind deflectors/spoilers. Anyone recommend them for the windows and, if so, which make? Then there's the bonnet one. Are they any good at limiting the flies and stone chips hitting your bonnet and windscreen?
Finally, it's been covered before, but i'd also like your recommendations on air suspension systems. Which makes should I be looking at?
aejcooper
Re: What Tub Liner and other stuff?
Post: # 12470Post aejcooper
April 9th, 2016, 12:57 pm
Hi
The Ford Ranger we mount our Tischer demountable on has the ford plastic liner in the truck bed, we mount and dismount onto this with no issue and so far has being holding up well to the demountable.
Thanks
Post: # 12479Post zildjian
April 9th, 2016, 7:39 pm
Drop the load liner in before you fit the eyebolts as liners have odd angles which don't effect where the camper goes but might prove a nuisance for the bolts if already fitted.
camper will flatten some of the 'ridges'' in liner if there's any movement on the road as it can then 'rock' back and forth worst case scenario
Hilux tailgate needs to come off in use with Skarosser as grey water tank conflicts with it unfortunately
tailgate weighs about 18kg with care its a one man job
Height is snug above cab but keep all four doors closed during loading in case you lower one side too much and touch one
I never have but noticed they can get get quite near sometimes,
Post: # 12480Post Peaky
April 9th, 2016, 7:48 pm
Sack the plastic tub liner idea, they collect dirt underneath them which in turn acts like sandpaper & rubs through the truck bed :cry:
Spend a few extra quid & get your bed spray lined. I've done this with my last 3 trucks :!: :!: :!:
http://www.speedlinereuro.com/
You won't regret it ;)
Madmountainman
Post: # 12482Post Madmountainman
April 9th, 2016, 8:38 pm
Peaky wrote:Sack the plastic tub liner idea, they collect dirt underneath them which in turn acts like sandpaper & rubs through the truck bed :cry:
I've sent for info and a quote on this, but still like the bed rug idea, though putting the removable carpet over this coating, when required, is also an option. My truck has a liner already fitted, but i'd already read about the sandpaper effect, so was after something better. If you don't mind divulging, either openly or via pm, what does this spray liner cost?
Madmountainman
Post: # 12483Post Madmountainman
April 9th, 2016, 8:45 pm
The previous owner had my camper on the Amarok, so he'd added a nice wooden frame to the base (of the camper) in order for the camper to clear the cab. This will mean no problems for me when I get to put it on my truck. I've not looked at it closely yet, but the extra height it gives may even allow the grey tank to clear the tailgate, but i'll still be taking it off all the same.
Post: # 12484Post Peaky
April 9th, 2016, 9:15 pm
I paid 450quid for my double cab 3yrs ago. It took 1 day to complete including the prep to the existing paintwork, it has to be sanded down so as to provide a good key for the spray liner. You can choose what colour, finish & where you want the liner to finish ie under rail or over.
Post: # 12492Post TrueDink
April 10th, 2016, 11:31 am
There is no problem dropping a camper onto a BedRug. I've been doing it for 4-5 years. I fitted a BedRug to make the dogs ride in the bed more comfortable. No damage to the bed and its removable.
Post: # 12554Post Alexd
April 13th, 2016, 10:29 am
With the load bed sprayed with a liner, is it still possible to use a bed-rug ?
These are handy for protecting delicate item from scratches and dents
Post: # 12555Post TrueDink
April 13th, 2016, 11:01 am
Yes. The spray liner is only a couple of mm thick so it wont impede the fitting of a BedRug.
