Flat tire - access to spare blocked by the cabin
terakota
Post: # 11916Post terakota
March 7th, 2016, 2:17 am
For this project you will need angular gear transmission of an old car jack. Something like this. Those carjacks belong to Fiat 750.
This is how my friend sorted it out. His rig: Toyota Hilux + Artica. He is the author of this improvement.
And this is how I sorted it out on my Nissan Navara.
Re: Flat tire - access to spare blocked by the cabin
Post: # 11917Post zildjian
March 7th, 2016, 9:21 am
Another good idea, and something that gets asked here by newbies quite often actually
Post: # 11918Post rubberrat
March 7th, 2016, 9:26 am
Engineering..the solution to everything.
Good article. I've checked mine and luckily the screwy 45` angle the crank goes in behind the number plate is accessible with the camper fitted. Just.
Post: # 11921Post sabconsulting
March 7th, 2016, 10:46 am
Excellent modification. Thanks for the write-up and pictures.
On mine the access hole is not obscured by the camper, but the overhang of the camper means you cannot swing the crank handle. So luckily all I needed to do was create an extension. I think in the end I welded a couple of sockets together back to back and that allowed me to use my socket set on the end of the square drive crank shaft. I say "think" because in 6 years I've never had a puncture, so never had to remove the spare wheel while the camper is on. I might try taking the spare wheel off this afternoon to make sure it hasn't jammed up there, or cracked. In fact I have another spare wheel and tyre in better condition, so I might swap them over.
terakota
Post: # 11923Post terakota
March 7th, 2016, 11:59 am
No new holes were drilled into the chassis. We used those which already existed there.
