Post: # 1831Post
November 1st, 2014, 2:27 pm
I'm just curious as to where people fit their valves for their air bags.
I put mine here.
Post: # 1833Post
November 1st, 2014, 2:35 pm
I have a 150mm base screwed onto the bottom of my camper to raise it above the Navara's roof bars so I can get at the electrics and the rear step no problem. The reversing camera still works fine too.
Post: # 1834Post
November 1st, 2014, 2:41 pm
- Site Admin
Post: # 1835Post
November 1st, 2014, 4:20 pm
I don't have a fill valve anyway at the moment as I don't need one,
my electrics though are beside tow bar and i'd love to move them as its the one inconvenient part of the hook-up.
did you read through Rubberrat's procedure for preparing to camp & what did you think
Post: # 1846Post
November 1st, 2014, 8:00 pm
How do you fill your airbags with no valve?
I did read the guide. It's very informative for the non initiated and a lot of effort has gone into it. Slightly different from my procedure though.
TrueDink on November 1st, 2014, 8:15 pm, edited 1 time in total.
Post: # 1847Post
November 1st, 2014, 8:04 pm
The airbags are filled with 2 Presto valves piped directly to each airbag with a portable 12v compressor to a preferred pressure normally somewhere between 60 & 80 psi
Post: # 1849Post
November 1st, 2014, 8:10 pm
I didn't even think about taking the air lines into my cab. It would have been a good option though.
Post: # 1850Post
November 1st, 2014, 8:14 pm
I tow a trailer so my electrics need to be next to my tow bar. I fashioned a splitter to take the current from the 13 pin socket on my Navara to the 13 pin plug on my camper and to the 7N and 7S plugs on my trailer.
Post: # 1851Post
November 1st, 2014, 8:47 pm
With reference to your 150mm spacer for your Navara roofbars. I to have an additional base for my Navara setup so I to can clear my roofbars.
I'm thinking of removing the roofbars though, as they're not used that often. Thus reducing the overall height of the camper & hopefully making the drag less & gaining a mile or so to the gallon
