What polish to use?
What polish to use?
Post: # 23161Post wonkywheel
August 26th, 2018, 10:15 am
Hi,
As my build moves slowly on I am at a point where the protective film on the fiberglass sheet has to come off. It is beautifully clean and brilliant white. Is there anything I can use to help protect it and keep looking good? like Autoglym?
Is there a particular polish that you would recommend?
Thanks,
Mark
Re: What polish to use?
Post: # 23183Post zildjian
August 29th, 2018, 6:39 am
As I thought then Mark, they are none of them keen on polishing stuff in fact. :roll:
Post: # 23204Post wonkywheel
August 30th, 2018, 6:57 am
Zildjian,
back to trial and error then :roll:
Ogden scamper
Post: # 23208Post Ogden scamper
August 30th, 2018, 6:20 pm
thats easy; Mk1 elbow grease is still king Wonkywheel :)
Post: # 23211Post mjb666
August 30th, 2018, 8:50 pm
Rightly or wrongly, each Spring i T-cut & wax polish the whole exterior of my De-mountable. It always looks better & the rainwater beads off it. I have no idea what you're supposed to use/do?
Amanda_P
Post: # 23232Post Amanda_P
August 31st, 2018, 9:35 pm
They do say that old-fashioned hard wax and lots of elbow grease is the best - but on a big camper body, it takes aaaaages!
I like Mer Ultimate Shine Polish. You can sometimes find this in Halfords, or (oddly) The Range. It leaves a good shine, leaves water beading and running off readily, and goes on relatively quickly and easily.
Quick tip - apply it with a damp cloth or to bodywork still wet from washing, and it goes on really easily. Then wait until it dries to a swirly haze, and polish it off with a dry microfibre cloth (i.e., a fluffy towel) or polisher.
You can also use it as a very, very mild cutting compound, so if you find a spot where a small scratch or stain needs a little cutting, you can just 'apply' it a bit harder to that spot.
I have no shares in Mer, I'm merely a satisfied customer. And 500mls lasts for years (as long as you don't knock the bottle over...)
Post: # 23239Post wonkywheel
August 31st, 2018, 10:10 pm
Thanks,
Amanda, I have been trawling some boating forums as they tend to polish each year, but I will look out for Mer. The tips on application are particularly useful as I tend not to polish the truck. I just have it spray polished after the car wash. I just have to wait until I have stuck some decal/graphics on as I need to do that or the polish should stop them from sticking.
Mark
Post: # 23406Post mjb666
September 12th, 2018, 7:25 pm
Hi Amanda
I finally managed to track down a solitary bottle in a local Range store.
Hoping to give it a go soon & remembering your application tips.
Mike.
Post: # 23484Post mjb666
September 17th, 2018, 8:34 pm
I had a spare hour free over the weekend and decided to give the new polish a go.
Well, three hours later and i have polished the rear end around and including the stable door.
It was much easier to apply and less messy than T-cut. I'am really pleased with it.
Thanks for that suggestion.
Mike.
