'Toecutter' is 71 years old...(gulp)
Post: # 21834Post zildjian
May 11th, 2018, 8:22 pm
My favourite character in Mad max
aside from sidekick Bubba Zanetti,
but does it make you feel that bit older knowing his 71'st birthday is on Friday next :roll:
http://madmax.wikia.com/wiki/Toecutter
Re: 'Toecutter' is 71 years old...(gulp)
Post: # 21869Post zildjian
May 14th, 2018, 8:25 pm
As mentioned elsewhere, the sequel (inline with most sequels) is pretty unimaginative,
but was good to watch this one again
Post: # 21870Post zildjian
May 14th, 2018, 8:29 pm
Also I had no idea the amount of conjecture on Mad Max over the years....
Toe Cutter I believe got his name from the fact that he's in a motorcycle gang of almost all sport bikes, when you corner on a street bike and drop down on the clutch side, if your clutch is set up stock (1st gear down, five up) you run the risk of your toes dragging on the ground if you get real low.
Hence Toe cutter is someone who rides hard, gets low in corners,
