Curious
Re: Curious
Post: # 1872Post zildjian
November 3rd, 2014, 8:49 pm
Well the cold weather is coming and that almost always means leaks, it seems routine as the temperature drops the push fittings seem to fail a little.
so are you using compressor daily or forecort?
Re: Curious
Post: # 1881Post TrueDink
November 4th, 2014, 2:53 am
I'm using a rechargeable battery powered compressor so I've got no need for a cable trailing to a 12 volt socket.
Re: Curious
Post: # 1882Post zildjian
November 4th, 2014, 10:59 am
Not seen one of those, how much are they & how long will they run?
Re: Curious
Post: # 1886Post TrueDink
November 4th, 2014, 2:55 pm
Re: Curious
Post: # 1896Post zildjian
November 6th, 2014, 3:24 pm
Blimey a gadget I'd NOT seen,
On TV there's some competition to win a shedload or 'ryobi' power tools that have one shape battery to fit all,
Your compressor with an electic drill to wind the legs all running off one battery would be good though
richc
Re: Curious
Post: # 1897Post richc
November 6th, 2014, 5:21 pm
Nah
Get a proper compressor.......
http://www.mattsavage.com/acatalog/400P ... 40043.html
OK I got mine when I had a small business selling off road accessories so it came in at trade price, but they are a fab piece of kit and will still be working when the Halfords one has gone to the great recycling site in the skye
Will put 90 psi in my Ivecos tyres
Re: Curious
Post: # 1899Post zildjian
November 6th, 2014, 7:37 pm
that's my spare
thing to remember with those is make sure you leave the engine running in use or you might well find not enough battery to start the car afterwards
Re: Curious
Post: # 1900Post zildjian
November 6th, 2014, 7:42 pm
The viar fitted beside motor under the bonnet is about the same size
and fills a 5G tank beside spare wheel, and that cuts out at 140PSI.... so they are indeed quite capable machines.
normally they end up on the low-rider market on VW dropped golf's and the like,
but are available in the UK
richc
Re: Curious
Post: # 1902Post richc
November 6th, 2014, 8:22 pm
Overlanders use them a lot - in sand the mantra is to drop tyre pressures so you need a reliable and easy way to get your tyres back to proper pressures.
we even have tyre deflators which can be set to a certain psi to deflate tyres.
toys toys toys......
rich
ps matt is an official distributor for viair in the uk, also a friend , thought i should own up to that
Re: Curious
Post: # 1904Post zildjian
November 6th, 2014, 9:46 pm
Wish I'd known that before,
the 'only' fella locally has recently given up fitting out cars as now does town bars full time (less hassle)
so now we don't have anyone really
luckily he sold me enough hardware to transfer between vehicles otherwise I would have had to import some of it
and I hate buying stateside as I almost always cop for import duty
