Solar panels
richc
Re: Solar panels
Post: # 5836Post richc
May 12th, 2015, 9:47 am
What is the size of the wiring as you are quadrupling the current
If it is 4 mm then you will be fine but less than that I would run new cable
You will prob need to upgrade the charge controller
this is the one we used for my dads camper - teach me to be a cheapskate
http://www.bimblesolar.com/20amppt?gcli ... wgodVngA7w
the 2 leisure batteries should really be the same make, age and size, wire them in parallel and you just use the one output
you also wire the 2 solar panels in parallel
cthodgson
Re: Solar panels
Post: # 5950Post cthodgson
May 17th, 2015, 1:50 pm
That's great Rich, thanks so much for the info. I'm going to have a go at this in a weeks time.
