I don't suppose you have unscrewed that connector and noticed which two wires have been connected to the same pin?Toshbins wrote:When be bought our Tischer earlier in the year we decided to power it from the tow bar socket, rather than fit a socket in the front of the tub as recommended by Tischer. I think Tischer may have been using a 13 pin plug since before they were used on tow bars but they have their own wiring scheme and won't change it. Nolan has to modify the extension lead that he supplies to convert the standard towbar layout on the male end, to the Tischer one on the female.
I gather that these hi tech fridges needs two live feeds to get it to actually run/work via 12 volts, I tried tapping into the leisure battery feed first, the fuse in the truck blew, I then tried the ignition switch live, fuse blew again.
I don't get it, there isn't another live in there for me to try, any ideas anyone?
