and 4 just no 1 to fit new back panel with a zip
- wonkywheel
Early start ready to take the dog. The dog went back to sleep on the settee so I finished No 3
- wonkywheel
A couple of thumbnails to substantiate my new found sewing skills
The unpicking tool was used most
. I even managed to sew the top to the bottom diagonally
Binding double sided sticky tape and a zip
Once they were all sorted they don't look bad for a bloke
Bearing in mind they have No wadding yet for that soft touch
or any upholsterers silk( slippy sheet to help it all go together and protect the foam from any water ingress). With a Draylon material and the silk, I should be able to sit on them in the rain
( Just don't go near the FIRE
P.s. I still haven't found any silk to purchase other than in 100meter rolls so anyone out there??????????????????
The wadding or even a steam iron might improve then even more
Please note the marble effect table top in its REST position
The bedroom is moving on at quite a pace
Insulation under the bed and on the walls. ( NS on them means they are NOT STUCK yet)
A slight repair was needed.
The fiberglass under bed sheet was not in contact with the spars in one area so I got out the farm jack and pushed it up to reglue it.
Push it up
I lifted the whole nose of the camper off the ground
fractured two of the welds in the process
That repaired. Plywood base sheets overlayed
I am going to put some of the insulation sheets over all of the area ( BIG Jim
) When I get some.
Also, when I can source some hardboard big enough to cover the ceiling. (unable to get an 8ft x 4ft sheet YET) I will be ready to carpet walls and ceiling with oatmeal carpet
(Starting to feel quite arty
Bribed my grandson to come over and help. (£££)
He managed to take all the edge angle off and remove the protective film off the whole camper apart from the 2 back sheets which I was prepping and gluing in position. Then he replaced the angle.
I now have a pristine white camper crying out for decals and color
Good job Jared, Thanks.
My attention then turned to THE DOOR
That bloody door.
I realigned the framing spars.(big hammer and drift) Rewelded the cracked joints
I Gave up then
I have resigned myself to the fact that I will be camping next week in a tent
again, but if I can get the camper bolted onto the truck I might take it to Santa pod as a sort of storage shed)
Some toerag removed my Tonneau so I need somewhere to keep the kitchen sink and all the other things you need when camping
I'm sorry if this post appears a bit disjointed but I'm just back from the gin bar
Saffron Gin
Push it up
That bloody door.
I Gave up then
Saffron Gin
More power to your elbow Mark
That made for an excellent read & has certainly lifted my friday evening after a long week at work.
No end to your skills, keep it up.
- wonkywheel
Damson Gin tomorrow if the neighbors out
- wonkywheel
Yes, I did pick 5 Kg of Damsons ready to have a go at some Damson Jam, Gin, Chutney,??? but I found time to do a bit more.
I finished gluing the back panels on(just the top edges which were screwed into position to glue the rest of the sheet) So now I have a white shiny cabin with NO DOOR
and it looks like rain tonight
At the minute all the sheets are glued in place but, all the angle ali is only screwed in place with no sealing mastic under it. This became obvious when my grandson was removing it. Particularly on the nose section. When he took the screws out the aluminium box was full of water and sprayed him
As the rainwater runs down the nose it can enter under the angle and without all the screws being in place get into the box section or sit in the supporting heavy angle. (Well that's my best guess
Bottom left you can just see the empty window cartons that have been removed from the barn for recycling
The cartons were taking up a lot of space and only contained the window bind cassettes. Although It's not really time to put them in at least they are out of the way
The top section is a fly screen and the bottom, blind, standard sort of thing. I think I will still have curtains to make it less rudimentary when I get onto the inside
I think they look quite good
. The blue ribbon is just there to make removing the cover trim to get to the fixing screws, not a fashion statement
Upon reviewing the post
I said all the sheets were glued in place. That is not correct. The 2 "L section pieces at the bottom rear below the ali trim line they are only held in with screws at the minute. I will be looking to put storage locker doors as well as the services inlet/outlets. There will either need to be added bracing to support them or I might back the fiberglass sheet with a piece of 3/4 ply to be able to have something for the fixing screws to go in. I think probably the gas outlet nearest the top with the 16amp inlet socket below it on the left-hand side with water in/out on the right -hand side. That way the water and mains electricity are not on top of each other and the water services are below the shower/ toilet room (cupboard
Having never been to a camper hook up I do not know which side the services are generally placed
Ok , I know it depends on whether your nose in or back in but there must be a normal average??? anybody
- wonkywheel
Doors seem to be like buses
You wait for ages for one
Then 2 come along together
Its true they are only the outer skins, no handles or locks, and don't fit as well as they are going to have to but...............
DOORS
I have said that I had given up on the dream that I would be using it this weekend at Santapod. With that in mind and the fact I no longer have a tonneau
I needed 3 or 4 more sheets of insulation board so as a cover for the tub I made a mountaintop out of 1 sheet of insulation and 2 rolls of gaffer tape
It certainly won't stop a determined (or even casual) thief but it will keep the contents dry and out of sight of prying eyes, stop things flying out the back and It will also help the efficiency of the cool box in the tub
With a roughly watertight box now that's it until next week now. Tomorrow will be shopping and packing up ready for the off on Thursday. With the Finals meeting being so popular the camping area is always cramped unless you get there early. With the prospect of rain, the site is even more important as a quick downpour can leave areas under water.
Looking forward to a chill-out long weekend with good company, beer and Drag Racing.
DOORS
- wonkywheel
The tented Santa Pod meeting was most enjoyable but I had forgotten
how much condensation you get on the walls of a tent
That reminds me, I must take the event shelter out of its bag to dry properly before it stains with the dreaded mildew. That's the trouble packing away on the last day before racing starts at 9-30
The doors still need a lot of work to get them functioning correctly but as I intend to fit windows in both there will need to be bracing in place to support them so I will wait until I have decided the positions. I did go ahead and fit the door lock so at least it has a small deterrent against would-be intruders.
With the days getting shorter it will soon be time to get some lights inside so that I can continue to work in the evenings(
fat chance) No doubt it will be getting colder too so I fitted the mains power in box to the shell so that I can have mains lighting and a heater should the need arise. Its true I still need to fit and wire up the consumer unit and a couple of sockets but Rome and demountables were not built in a day,
mine certainly
While I was into cutting holes in the panels I thought I would put the LPG out socket in as well. In an effort to be neat and tidy I put it a bit close. It had to miss one of the spars. I could have done with about 10 mm higher. There might be a modification pending
Next, I turned my attention to drilling holes for the lighting array
It was only after I had positioned them, drilled the holes for fixing screws and wiring that I noted they are not "E" marked. That means technically I believe they are not actually legal as main rear lights
It is true they were always going to be temporary as I have my heart set on a set of "Hamburger" style light when funds are available.
I am, as yet, undecided as to where to put the number plate. Dead center would place it on the door with all the problems of wiring plus window and steps. So it will more than likely go to the left side
That's all for now folks
- wonkywheel
Inch by inch, brick by brick the camper moves slowly forward and upwards into a position that will allow me to ensure the legs fit and have enough movement.
I want to be able to fit the legs soon
so I will need to make them
I have the winding head design sorted, I think, although like most other things UNFINISHED
The actual legs and their fitting is still undecided. I think I know but until I can stand everything in place I don't want to cut the aluminium. I have already changed my original design (which I thought was over-engineered) and opted for a smaller section box and tube.
To be able to do that I need the truck up against the camper to check width and height
The skip find from my old workplace is coming into use.
The height is almost the same as the truck bed and the large castors will allow me to push it about. My plan is to try to get it equal about the linear centerline.
This should leave me with an overhang at the front to which I can offer the truck up against
The process of jacking it up (with my farm jack) fitting wooden blocks, con blocks, engineering bricks or whatever came to hand, took quite a while.
Eventually, I was at a height that I am happy with for the time being. I had to raise the front, then one side, then the other. Back to the front for another inch or so. I didn't want to get too much of an angle on it for fear of it sliding off the blocks. It only did this once, at the front, when the jack got away
as the whole thing slewed sideways
. Luckily, I always had a secondary set of back up blocks at the previous height so it didn't go very far
I lost count how many times this was repeated.
Getting the height was bad enough. Then I needed to move the whole thing forward
With the nose end resting on the trolley I was able to jack up from the center rear
just enough to allow the camper to fall forward back onto the support blocks. Move the blocks forward and repeat untill had enough
Not one for any Health and Safety or any other thread
The camper is standing on a concrete block with a couple of blue bricks on top.
Back up is axle stands standing on a concrete slab standing on a car wheel
Oh and the secondary back up my caravan steps (which saved the day in the high winds)
With this setup I should be able to sort the legs
Hi Mark
If you need a couple more pair's of hands lining things up, contact Zildjian, and i'll see if i can get a saturday to drive up, pick him up and we'll drive over to help.
Mike.
Mike.
And with that carrier under it I can bring the weighing kit, we can stand the weighing pads on that & camper on top of them
simple
simple
