I spotted these picture's on a Facebook page that i'm a member of. I thought it might be of interest to potential new owners to show the importance of matching the right De-Mountable to the right base vehicle.
imagYours could be used as a great example of exactly what a perfectly balanced demountable camper and truck combination should look like.
Good point. I suspect the problem is the difference between pure tension, which tub mounts would be under, which they could probably resist quite well, and bending, which the chassis would be under. The chassis would have no problem handling that flex if it were static, but I suspect the continuous flexing while driving over a road surface would be like taking a spoon and bending it backwards and forwards gently, and by a tiny amount each time, thousands of times until metal-fatique caused it to fail.TonyS wrote:...Its unclear as to exactly where the pod is tethered at the front end. was it tethered directly to the chassis, effectively sandwiching the load tub between the pod and the chassis. . . or, If it was strapped to the load tub only, why did the comparitively fragile tub bearers/mounts at the front not give way before the main chassis rails bent. . .is this further reflecting the weakness in the chassis itself?...Tony
