free picture upload
how to screen capture2. I purchased four of these trailer legs from E-Bay for £120 inc delivery with 1500KG Max load on each as a starting point
imgurl3. As the unit had locating/mounting box sections at each corner under the floor & a screw above to hold the leg against the side , a similar approach was decided upon for the new set-up.
image hosting over 5mb
how to capture screen4. The most obvious problem for the two legs at the front was they were too short so the base plate was cut off, welded to new over size tubing which in turn was welded to the original leg which in turn gained the extra length required.
image hosting 10mb limit5. Using the old set-up took about 45 mins to load/unload. It now takes about 20 minutes with approx 10 turns of each handle to raise it high enough to drive out from underneath & it can also be lowered close to the ground when on site.
6. OK, i admit i have cheated because i have a Great Mate who can turn his hand to most things, i can't, so Thanks Luke. Total cost for the four legs was approx £400.
PS. They do the job & look pretty smart too.
