Servicing Swedish Skarosser legs
New link to this brilliant wealth of knowledge on the subject
Badger
Post: # 11940Post Badger
March 9th, 2016, 2:33 pm
Hi, I am new to this forum and have already found it very useful. I have an S-karosser EC6l and my legs are getting a little stiff. I was wondering if anyone had taken theirs apart to re-grease and how it went?
Re: Servicing S-karosser legs
Post: # 11941Post zildjian
March 9th, 2016, 3:02 pm
Hi welcome to forum, sure just pop the black plastic bungs out of the top and add some grease to the cogs inside,
as well you can just lengthen the legs until the lower half drops off the thread apply a glob of grease to the nut on top and reassemble, that is usually enough.
usually a combination of water ingress via those same plastic caps ( can get these) or the leg has got slightly bent in the past
worst case scenario NSR Wales can order you a new leg or more from Skarosser at a price
Badger
Post: # 11942Post Badger
March 9th, 2016, 3:11 pm
Thank you Zildjian, that is very useful information, your reply has given me the confidence to wind them apart and re-grease. Many thanks.
Here are pictures of my camper.
I bought it second hand in 2014 and the picture on the Isle of Barra at the bottom of the outer Hebrides was the first trip I did. I was living in Sussex at the time and I probably, should have gone somewhere slightly more local for a first run, but it all went well.
Image Image
Meki
Post: # 11944Post Meki
March 9th, 2016, 8:09 pm
Looks a clean demountable mate, welcome to the club
Post: # 11947Post TrueDink
March 10th, 2016, 1:49 am
Hello and Welcome. Similar set up as mine except my Navara is silver.
Post: # 11948Post Peaky
March 10th, 2016, 7:00 am
Welcome to the group Badger, I hope that your finding plenty of useful information on here & please don't hesitate to ask for any additional help. I to have an Skarosser on a double cab Navara & have carried out some pretty extensive work to the chassis.
Have a read of this thread & my report along with the photos link. You should find it interesting ;)
viewtopic.php?f=19&t=334&hilit=chassis&start=100
Andy
Post: # 11953Post Mike
March 10th, 2016, 8:41 am
Welcome to the group sure you will find many answers to your questions here
Cheers
Post: # 12201Post zildjian
March 26th, 2016, 4:41 pm
How did you get on inspecting those parts,
I have a new batch of replacement end caps here ready if they got chewed up during removal
Badger
Post: # 12262Post Badger
March 30th, 2016, 4:49 pm
Hi, I have not got round to doing them yet, everything is still battened down for the Winter, but when things warm up a bit I will drop the camper onto the bed of the truck and take the legs off and give them a service. My caps all look in good condition, but if that changes I know who to contact thanks.
Badger
Post: # 14892Post Badger
August 18th, 2016, 10:57 am
zildjian wrote:How did you get on inspecting those parts,
Hi Zildjian,
It all went reasonably well, the caps are all ok on mine, I have greased the gears and replaced. I also wound out the removable front legs so I could grease the nut which also went well, however on investigation I tried to remove the smaller non removable rear legs to do the same process and gave up in the end. They were too difficult to remove. Other than that all good thanks. :)
