Bas Landrover
Re: Bas Landrover
Post: # 3550Post zildjian
January 26th, 2015, 8:38 pm
We shall follow this build with interest so be sure and take lots of pictures Bas :D
Re: Bas Landrover
Post: # 3563Post derestrictor
January 26th, 2015, 9:23 pm
Bas likes his landrovers doesn't he :mrgreen:
landrover130
Re: Bas Landrover
Post: # 4146Post landrover130
February 13th, 2015, 8:43 pm
Yep, that's my ride.
I'll post some more updates, with build plans and some pictures and links soon.
Will begin with the welding in March.
Bas
http://camper.utomhus.nl
Re: Bas Landrover
Post: # 4147Post zildjian
February 13th, 2015, 9:02 pm
Any problem with images just mail me them through the 'email us' option and I'll post them up and yes the more detail the better so take lots of pictures please :mrgreen:
landrover130
Re: Bas Landrover
Post: # 4338Post landrover130
February 22nd, 2015, 9:51 pm
Did another small update today. Had to fix some temporary wheel arches to the 130 because it needs a new registration (in order to keep low taxes when I mount the camper, stupid dutch laws). With the small platform that was created I could setup a wooden template to check the dimensions of the camper unit.
Read all about it here:
http://camper.utomhus.nl/everything/thi ... /#lightbox[gallery-1]/4/
Click on thumbnail to display please
Re: Bas Landrover
Post: # 4341Post zildjian
February 22nd, 2015, 10:40 pm
Like the progress Bas, what do you have planned for canper interior?
Re: Bas Landrover
Post: # 4354Post zildjian
February 23rd, 2015, 3:23 pm
Bas I've added a thumbnail image below yours as original is not displaying properly here Zildjian
Re: Bas Landrover
Post: # 4379Post derestrictor
February 25th, 2015, 1:58 pm
What is the construction method for the camper then Bas, it looks like a great outfit all the same
well done
landrover130
Re: Bas Landrover
Post: # 4388Post landrover130
February 26th, 2015, 7:57 am
Construction:
I will start by making a frame out of square aluminum tubing. Bottom will be 40x40x3 and the rest mainly 30x30x3mm.
Will be a light frame that is covered by an aluminum skin (2mm bottom / 1.2mm rest) glued with an MS polymer.
The frame will be isolated with 4cm XPS / Styrodur isolation plating glued (a closed cell isolation) and the tubing will be covered with 1 cm isolation to prevent the aluminum from conducting the cold (cold bridge in dutch?0
hébergeur image gratuit
image a telecharger gratuitement
hébergeur d images gratuit
The interior will be finished with a 3mm wooden layer.
I will try to upload a building plan.
Bas
