Hi from Poppi in Devon
Re: Hi from Poppi in Devon
Ok I have sent a pic of Daisy and her inside too
I am not sure if it can actually be demounted easily as it is bolted to the frame of pick up and no bed has been left in place so probably not.
I sometimes have my skye terrier with me and have a 17yr old son who is off to uni in September.
I have a vango tent canopy which i attach to rear of Daisy by the awning channel and intend making a sun canopy at some point for the side awning rail.
I don't think i will bother with attaching solar panel to roof but keep it mobile . I only need it to keep the leisure battery topped up as i don't have a split charge unit and like to keep things simple.
Poppi
well in that case you might get away with a suitcase arrangement,
literally in a suitcase you fold it open and point it skyward, hook it up directly with crocodile clips to battery then just put it away again after,
can you reach LB easily?
- derestrictor
Looks cosy Poppi, whats the heating like?
zildjian thats is what i thought and bought a small suitcase panel and each time i came home plugged it in on drive but it didn't top up battery but obviously havent tried it on a good battery as mine needs replacing.
Derestrictor I don't have any heating in her but through winter when on drive i plug her into house and have a tube heater inside just to protect fabrics and furnishings from damp and mould really.
She is my only vehicle so is used regularly.
Poppi
sensible to add a cheap heater over worst weather, an oil filled rad costs pennies daily to leave on low and its best Poppi to not let a leisure battery go flat either, they don't like it
and in my case its not only the expense, its a devil of a job to swap it too
Is yours a pain to swap because of that bulkhead on the SKarosser? I lopped 15mm off the bottom with a jigsaw, remove water pipe too (if tank empty!) and out it slides.
There's not room to lift it out one end first in any way, a seat base has to come out and dismantle that step that peaky mended on his too
I'll try to photograph mine tomorrow to see what is different.
Poppi, I had a look at your FB page, https://www.facebook.com/PoppisUpholstery?fref=ts
would you like to put a few of your images in here and a note on what you can do ?
think it might be of interest to others here,
let me know and we'll start a thread on it and Peaky can add you to our links page too
Oh wow thank you zildjian that would be great ! I will email a few that i feel maybe relevantzildjian wrote:Poppi, I had a look at your FB page, https://www.facebook.com/PoppisUpholstery?fref=ts
Poppi
