360 tour of an Skarosser
Post: # 2569Post Peaky
December 12th, 2014, 11:08 am
This is a look at the inside of an Skarosser 6 s
If you click on the red button over the bed, it opens all the cupboard doors etc.
Enjoy ;)
http://www.panowelten.de/HTML5/wohnkabi ... sen_1.html
Re: 360 tour of an Skarosser
Post: # 2574Post rubberrat
December 12th, 2014, 12:26 pm
Thats some fancy stuff isn't it.
A couple of things I like on this over ours... That 'warm' wood - we have light Scandanavian style.
The mirror on the fridge - must see if Dometic to that as an aftermarket add on. And the window in the back door.
Ours has an extended kitchen (and corresponding shorter seat) to accommodate 4-burner hob and full oven.
I have to say, that from a marketing point of view, having a 360' video done is a really good tool.
Sheriff
Post: # 2577Post Sheriff
December 12th, 2014, 1:53 pm
I like the locking catches on the overhead cupboards. Ours doesn't have them for some reason, though it does on the big cupboard doors. Had to clear up a litre of olive oil and broken glass from the floor on return from our last trip. It's on my todo list.
Guy
Karosser Camp 6L
Toyota Hilux 3ltr auto
Post: # 2579Post zildjian
December 12th, 2014, 2:22 pm
Odd, I'd seen this before but a very long while back and I'd quite forgotten it existed,
Sherrif if your's doesn't have those locking cabinets I'm positive you can add them yourself, we have an ironmongers alongside us here at work I could go and take a look if you like its no bother,
mine also has a light pine finish but does have a mirror,
(although TBH not sure the wisdom of having someone applying
HIGHLY INFLAMABLE hairspray with the burners on behind her :shock:
do look good though new don't they,
ie not lived in
Post: # 2580Post Peaky
December 12th, 2014, 2:52 pm
Mine has the mirrored fridge & rear window to the door, but does not have the window or extractor above the burner :(
The timber is the same finish though & I've also only got the standard cupboard catches. It isn't really a problem though as we keep everything in baskets, so as avoid the falling out problem :P
Sheriff
Post: # 2583Post Sheriff
December 12th, 2014, 6:03 pm
Yes, it does look good, ours is a tad more scruffy. We have the light Norwegian wood (isn't it good?) effect and an oval mirror on the fridge door. I like the extractor over the hob, that shouldn't be too hard to fit. For the cupboard latches I was thinking of something like this:-
Cheapish, easy to fit and doesn't require drilling holes through the doors. http://www.caravanstuff4u.co.uk/door-lo ... atch-.html Zildgian, thanks for the offer - have you seen anything more suitable?
As for keeping everything neatly organised in baskets, nice idea but we operate more on the stuff-everything-in-at-the-last-minute-wherever-it-will-fit principle.
Guy
Karosser Camp 6L
Post: # 2584Post Peaky
December 12th, 2014, 6:07 pm
We find the basket idea great as you can simply lift out the entire contents in one go & have a right good delve / sort out & then just pop it back into the cupboard :P
Post: # 2586Post zildjian
December 12th, 2014, 6:51 pm
The latch mounted on the inside of door (obviously)
https://www.google.co.uk/shopping/produ ... P4CEKYrMBM
Then the knob & Rosetta
obviously you have a little 'keep' for that latch to lock over, (its just a little section or right angle)
https://www.google.co.uk/shopping/produ ... PEBEKYrMAg
look smart and very functional
Sheriff
Post: # 2589Post Sheriff
December 12th, 2014, 7:05 pm
Thanks Zildjian, they look a good match for the existing catches on other doors.
Guy
Karosser Camp 6L
Post: # 2590Post zildjian
December 12th, 2014, 7:34 pm
If you need a more detailed image let me know and I'll picture mine
