Demountable parts for renovating
Posted: March 15th, 2019, 3:52 pm
by Konrad
Hi Folks
I've gone and bought an L200 and an unknown year Skarosser I think. It requires a lot of work. No fridge, heater, batteries ,charger or even lighting. Has only 3 legs and the two back corners at the bottom let water in.
I was thinking of buying an old caravan to cannibalize the bits I need. Is there any reason why these wouldn't be suitable for you demountable? What kind of heaters do they normally have in them?
Re: Demountable parts for renovating
Posted: March 15th, 2019, 7:42 pm
Hello do you have any pictures of it yet?
I'm guessing its an earlier model which were pretty basic but would be helpful if you had something I could see,
in terms of a donor vehicle yes why not, in fact many of the components you might have seen in caravans back then,
Modern SKarosser eco models have a simple blower heater & no hot water anyway due to space restrictions and many people prefer the saving in weight and just boil a kettle!
Posted: March 15th, 2019, 7:58 pm
by mjb666
Hi Konrad
Good on you, you don't hang about once you've set your mind on something!
Out of curiosity, where did you purchase it from, just being nosey. Private seller?
An ongoing re-build/kit out progress thread with photo's would be Great as well, always helpful for others to see/learn, me included.
Posted: March 16th, 2019, 2:15 am
by Konrad
Posted: March 16th, 2019, 7:20 am
If you need help adding pictures, email either of us and we'll add them
Posted: March 16th, 2019, 9:09 pm
by Konrad
Hi I would appreciate the help with the photos. I've sent you a email but couldn't find anywhere to attach them. I'm a bit of techno dunce.
Posted: March 17th, 2019, 11:28 am
by mjb666
Hi Konrad
Zildjian will be your best bet for help putting photo's on the site but he was good enough to teach me how to do it & i was/am still pretty rubbish with computers.
If you want me to try as well, pm me?
Posted: March 17th, 2019, 4:07 pm
OK so rot in rear floor might be a result of having those rails torn off by roof steps and water just running in,
I fasten mine to truck at front by using the leg brackets and some custom made ratchets with a strap as the brackets offer best fixing, although there should be a couple of anchoring loops on underside (about where the seat are) and accessed by a lift out panel inside
Posted: March 17th, 2019, 11:27 pm
by Konrad
Thanks I'll try that. Do you know if it is a sarakossa? Do you know if anyone else has or had one so I can see how it should look.
Thanks
Posted: March 18th, 2019, 6:59 am
Handful of them here, I have one myself.
Made in Northern Sweden by SKarosser and marketed throughout Europe,
http://www.skarosser.se/
parts are available though due to coming from Sweden tend to be pretty expensive however many of the components are used in other campers so you can find them if you are lucky.
There is a buyers guide here for them though generally not much to look out for in terms of problems though usually
viewtopic.php?f=40&t=974
