Page 7 of 15
Re: Need to lose some weight/re-plating vehicle
Posted: June 23rd, 2015, 2:05 pm
by Sheriff
I've just got my re-plating through from SvTech - GVM up from 3210 to 3480, rear axle up from 1750 to 2010, tyre load rating of 110.
The process took about 3 weeks from emailing the form to receiving the new plate. I took forum advice and rang up a few times to keep it on the boil. Cost was the standard £260 + VAT. All very easy.
Thanks for the advice everyone.
Posted: June 25th, 2015, 8:02 pm
by FinAde
Congrats
.The next step is the V5. I sent it off with the certificate from SVTech on 20th May. I got a letter this week dated 15th June stating that my request was being dealt with, along with the returned certificate. Still no V5 though. A month to tell me they've received the application is rediculous
Luckily
I took copies of everything so will be travelling with all the paperwork 'just in case'.
Posted: July 2nd, 2015, 7:55 am
by Lost in the wilds
Just been to the weighbridge with the whole rig.
Tischer 230 (empty) comes out at around 710 kgs.
The limiting factor is the rear axle (weighed in at 1900 kgs, limit is 2200 kgs). Add water, gas, beer, etc and we should be OK.
Chris
Posted: July 2nd, 2015, 8:48 am
Beer huh, hmm sounds like gubment' man is policing our alcohol intake and using VOSA to enforce it,
They'll likely stop you at roadside offer to pour liquor down drain or slap a ticket on screen
Posted: August 10th, 2015, 4:48 pm
by Peaky
Posted: August 11th, 2015, 10:13 am
by FinAde
FinAde wrote:The next step is the V5. I sent it off with the certificate from SVTech on 20th May.
Well it seems the DVLA are as useful as a chocolate teapot. Finally received the new V5 to find that the Gross Revenue Weight has indeed been updated to 3500KG
but maximum laiden weight is only 3170KG
So back it has to go... with a gentle note (and much highlighter) that they got it wrong... bring on another 6 week wait.
Posted: August 11th, 2015, 11:19 am
We've just got our V5 back. Same thing - Revenue weight 3500 kg, Max permissible mass 3170 kg. I'm going to have words with SV Tech as it does not actually state on their declaration that the MPM is now 3500 kg.
More later, Chris
Posted: August 11th, 2015, 5:14 pm
From Gareth Marsh at SV Tech by email:
"After registration, the DVLA only have access to changing data recorded in section 7.
This is quite correct, and it is only the revenue weight that gets amended."
I phoned Gareth. I am not the first to query this. DVLA CANNOT change anything on the V5 apart from the blue section 7. Only the manufacturer can apply to have anything else changed.
Gareth recommends that if I am stopped by the plod to refer them to the plate that states GVM is 3500 kg. This is apparently acceptable to them. Whether that is the case abroad.........maybe I'll find out in time!
Chris
Posted: August 13th, 2015, 8:57 am
by FinAde
Lost in the wilds wrote:We've just got our V5 back. Same thing - Revenue weight 3500 kg, Max permissible mass 3170 kg. I'm going to have words with SV Tech as it does not actually state on their declaration that the MPM is now 3500 kg.
More later, Chris
Interesting as our certificate does state that the MPM needs to be 3500KG.
Too late now, I've sent it off, so I'll await the return of my V5 unchanged then.
Posted: August 15th, 2015, 2:48 pm
by Peaky
UPDATE No.1
I gave Gareth a call on Friday lunchtime to remind him that I was still waiting for his email.
After taking all my details again the email / forms arrived 5mins later with an apology to say that he must've got side tracked when we spoke last Monday.
I completed the form took photos & copied the log book & sent it all back within the hour.
I also asked in the return email about the price query.
So let's see what happens next
