New member needs help with Apollo revamp
Re: New member needs help with Apollo revamp
Post: # 13944Post zildjian
June 27th, 2016, 9:34 pm
YHM
Campsites near here I'll have to think for a minute on that one,
just try everything out, tap, heater, all lights some are mains maybe, most 12V and usually if Leisure battery is failing its a problem.
many things rely on a 12V battery in the EHU circuit to function properly, if its old you might want to think about replacing it
as despite being plugged in somewhere the fridge for example might not want to play.
Has it been fired up recently, the starter components on many of our at weekend were and consequently at least one unhappy couple had throw away nearly a fridge full of food!
so its important not to set off without being confident its all in working order, also if your seller was economical with the truth
I would get a habitation check carried out by a caravan gas man or at very least buy both smoke and monoxide detectors to be on safe side
