new one
Re: new one
Post: # 11832Post Toshbins
February 29th, 2016, 11:25 pm
My truck has a combined roller shutter and roll bar arrangement that is hugely heavy and awkward to lift off. So I've used an engine hoist and straps. It's still awkward, but at least I can do it on my own.
Kitch191
Re: new one
Post: # 11834Post Kitch191
February 29th, 2016, 11:34 pm
It lifts the canopy from the inside but I had to build up the height of the tool box on timber as the lift does not lower completely on to the floor.
exd"]so does that jack up the canopy from inside, or lift it from above with a strap or something?[/quote]
Kitch191
Re: new one
Post: # 11835Post Kitch191
February 29th, 2016, 11:40 pm
I looked at engine hoists but they lift from above I was lucky to spot this on e bay. I have a picture from the makers of this somewhere don`t know if they are still in production, I will try to sort it out & take a photo of it might give you an idea of how to adapt yours
Toshbins wrote:My truck has a combined roller shutter and roll bar arrangement that is hugely heavy and awkward to lift off. So I've used an engine hoist and straps. It's still awkward, but at least I can do it on my own.
Re: new one
Post: # 11872Post Bookend
March 3rd, 2016, 8:50 pm
I was going to adapt an engine crane like this but bought a second pickup for the camper :?
It going soon though so may look at doing this.
Re: new one
Post: # 11873Post zildjian
March 3rd, 2016, 9:52 pm
Wonder if its easier to have one lower with a wide spreader to lift against the roof inside canopy instead
wide so canopy wouldn't readily topple off, low enough to drop canopy on ground out of use
Kitch191
Re: new one
Post: # 11874Post Kitch191
March 3rd, 2016, 10:44 pm
The way you have drawn the lift is almost exactly the same as the design on the one I have the only thing is mine does not lower onto the ground it only lowers to 3 feet from the ground the design stops it going any further. I have to put it onto the other lift I have & move it around that way.
zildjian wrote:Wonder if its easier to have one lower with a wide spreader to lift against the roof inside canopy instead
Re: new one
Post: # 11875Post Toshbins
March 3rd, 2016, 11:13 pm
For the hardtop that I had on a jeep, I made a hoist to pull it up to the garage roof. It hung over the bonnet when driving in forwards. The pickup only just squeezes into the garage so there's not room to do it with the roller shutter and roll ar on the Amarok, so I've gone with an engine hoist. I only bought a one ton hoist, but with the extension that I've had to put on th arm, I wish I'd gone for a two ton one now. Seems to work though.
Re: new one
Post: # 11876Post TrueDink
March 3rd, 2016, 11:20 pm
Kitch191
Re: new one
Post: # 11891Post Kitch191
March 4th, 2016, 8:44 pm
Looks like a nice sized garage Have you thought of a pallet lift. If I had a larger garage I would use a fork lift or pallet lift & replace the forks with a platform similar to the drawing you have made standing against the wall you were reversing toward with the door open on the top & reverse under the lift then lift it off .The arm could be made to come off when not needed
All that you would need to do is change the lifting system as these are lifted from a handle at the rear
TrueDink wrote:viewtopic.php?f=19&t=522&hilit=top+removal
Here's how I do it.
Re: new one
Post: # 11896Post derestrictor
March 5th, 2016, 10:08 am
there are manual palet lifts after all think machinemart sell them
