Posted: June 8th, 2019, 3:31 pm
This has been the first chance I have had to check out the camper since we returned from Exmouth.
I remembered hearing some strange lumps and bumps on the way back from Santapod the other week and the threads I had read about the Suntreckers flexing slightly and tapping the truck cab roof came to mind. I re-read them again this morning and went to inspect the underside of the cab-over bed when it stopped raining.
There are definite signs that there is some movement. It could have been in part my own fault as I found I had failed to tighten the LH bed clamp onto the tub, although there are 3 others
The design was intended to just miss the roof bars without the need to remove them. The noises I heard seem to have been the camper moving the roof bars along the truck roof. I am thinking that the bed liner allows the camper to rock under adverse condition (camper field ruts). This has then moved the roof bars a little at a time until the rear one was close on 100mm out of position. I could see by the dirt marks on the truck roof it had been a bit at a time.
I am going to need some packers to lift the whole thing slightly higher.
I am unsure whether to fit stips between the corrugated bed liner to alleviate the flexing at the same time. As I need more Celotex insulation board I might go for 25mm (which is what I am using) a piece of 6mm ply as a weight spreader with 4 strips of wood that fit in between the corrugations. Or, just fit a chunk of 18mm ply to the bottom of the camper. (quite heavy
Whichever way, I need to get these things sorted smartish. I don't want to miss the Pizza
Ps
While on holiday I did have a little play with my raspberry pi computer(7-inch screen) with the intention of putting it in the camper
It only uses a 5 volt supply as its an arm phone chip running it
Ps
