Air suspension
Re: Air suspension
Post: # 5932Post Bookend
May 16th, 2015, 6:09 pm
All look ok I'll see what happens overnight
surfglobe
Re: Air suspension
Post: # 5941Post surfglobe
May 16th, 2015, 9:11 pm
thanks for the pictures great help glad it went well
Re: Air suspension
Post: # 5942Post zildjian
May 16th, 2015, 9:25 pm
Typically Tony, they don't cause any problems,
but because you have to remove the rubber bump stops on axle case (and those sometimes need an air tool or even heat to loosen them) otherwise it would be a DIY job definitely.
Re: Air suspension
Post: # 5943Post Bookend
May 16th, 2015, 9:30 pm
The hardest part of the job was to undo the ubolts but I sprayed WD40 on and wire brushed the threads then sprayed again and cleaned with an old tooth brush.
Wasn't too bad with a impact socket and a breaker bar.
Re: Air suspension
Post: # 5944Post Bookend
May 16th, 2015, 9:38 pm
surfglobe wrote:thanks for the pictures great help glad it went well
Are yours the same or different?
Re: Air suspension
Post: # 5946Post Bookend
May 17th, 2015, 6:25 am
The pressures are the same this morning so that's another job off the list.
