Bas Landrover
lamp-it
Re: Bas Landrover
Post: # 6513Post lamp-it
June 16th, 2015, 8:56 pm
Has this camper been finished does anybody know? the last time I looked at this build there was some welding taking place and was hoping to see what happened
Rob
landrover130
Re: Bas Landrover
Post: # 6518Post landrover130
June 16th, 2015, 10:27 pm
Yes, lot's of updates but been too busy to share them, I'm sorry...
I made loads of pictures that I will post one day... ;-) For now here's a link to some images I uploaded to Facebook:
https://www.facebook.com/baswit/posts/1 ... nref=story
Where am I at now:
- the unit is mounted on the land rover, pretty satisfied with the way that worked out. Taking it on and off is fairly easy and can be done by just me in 20 minutes.
- the roof is almost ready: have to fix the roof panels tomorrow and fit the gas struts. That will be the moment to see if all works out as planned (the other struts were way too strong)
- door is being ready to be fitted
- starting with the build of the interior.
Next week I will place airlift suspension in the springs at the rear to cope with the extra weight (although now it weighs around 380kg, fairly light for a 200x225cm with a 200x375cm roof) and fix the spare wheel to the front bonnet.
And start making the canvas for the lifting roof.
I'll try to give some more updates!
Greetings Bas
landrover130
Re: Bas Landrover
Post: # 6519Post landrover130
June 16th, 2015, 10:28 pm
lamp-it
Re: Bas Landrover
Post: # 6533Post lamp-it
June 17th, 2015, 8:54 pm
we were wondering if you had been weighing the materials during construction and see now you have, good to see this project still progressing :roll:
Rob
Re: Bas Landrover
Post: # 12467Post zildjian
April 9th, 2016, 12:26 pm
Latest images
more pieces in the puzzle
We had some pretty serious rain and I knew I had one small leak. But other than that it held up super. Space is perfect just some small additions before taking on Europe;-)
landrover130
Re: Bas Landrover
Post: # 12510Post landrover130
April 11th, 2016, 8:49 am
It's been quite a while since my last update.
Didn't do a whole lot last fall. Work and other issues kept me from working on the camper. But since January I've been very busy.
The interior has come quite a way, I even built the sitting benches twice.
A few challenges are left. I'm still not satisfied with how the lifting roof works. And I need to come up with an alternative solution for filling the fuel tank. The fuel filler over the chassis wasn't big enough in diameter (it was a flat tube) and filled way to slow.
I'll keep you posted!
Bas
Re: Bas Landrover
Post: # 12528Post derestrictor
April 12th, 2016, 8:09 am
It has been awhile since picturse but worth it Bas you must be pleased to have something constructed from that pile of pieces on the floor last time
First night out using it!
Post: # 14027Post zildjian
July 2nd, 2016, 9:25 pm
Image Image Image Image
'We had some pretty serious rain and I knew I had one small leak. But other than that it held up super. Space is perfect just some small additions before taking on Europe';-)
Re: Bas Landrover
Post: # 14028Post derestrictor
July 2nd, 2016, 10:03 pm
Well that worked out pretty neatly in the end Bas, well done Now I suppose there will be a few changes and improvements as you go along
Re: First night out using it!
Post: # 14036Post Alexd
July 3rd, 2016, 9:26 am
Not bad going there bas
For a scratch build, that shape really suits the 130 chassis, sort out the leak and you are all set
zildjian wrote:Image Image Image Image
