Outdoor shower ideas please
Pictures from 'The Walshyway'
Post: # 20038Post zildjian
November 20th, 2017, 12:40 pm
Image Image Image
TheWalshyway
Post: # 20049Post zildjian
November 20th, 2017, 10:12 pm
The pictures above are from my internal shower setup in my Suntrekker, the container is 10 lt and would do me for 2showers or 1 plus a bit for my wife when it's Hair day
We just boil a kettle to heat, I have black taped the container to place in the sun before adding the kettle.
The shower cubicle is sealed at the base so I just reverse the flow when finished and fill the container with the used shower water for disposal.
The cubicle came with a full pole assembly but I only use the ones in the picture ( a lot less time needed) the pump is a submersible one.
I also have the black floopy shower bag for a post beach shower however you need to take the plastic tap apart and make the hole larger when it's *on* and also it helps if you make the head holes larger
Re: Outdoor shower ideas please
Post: # 20053Post Big Jim
November 21st, 2017, 7:43 am
Thanks for the photos.
I like this idea and the Suntrekker has a perfect roof shape for this if mounted to one side .
https://www.youtube.com/watch?v=dG2HK9JsAjw
Post: # 20095Post zildjian
November 25th, 2017, 10:02 pm
just found this on pinterest, not sure its been done before but looks interesting
