Oh no what has happened (Ranger repair)
Re: Oh no what has happened
Post: # 885Post zildjian
September 14th, 2014, 8:13 pm
Can we have one of the whole of the back of the camper as well if you can
Post: # 966Post Mike
September 16th, 2014, 7:23 pm
Rear view
Post: # 968Post Mike
September 16th, 2014, 7:34 pm
Top of jack mounting bracket they all need some paint now, will use some white hamerrite I think
2nd waterproof coat on the ply back panel
Post: # 973Post zildjian
September 16th, 2014, 8:30 pm
Mike you need an avatar to go alongside your name but it should be a positive one
use this easy maker: http://www.shrinkpictures.com/
Post: # 974Post zildjian
September 16th, 2014, 8:31 pm
Good 'carpenting' BTW
Post: # 1054Post FinAde
September 22nd, 2014, 11:26 am
Looks like you're making some good progress. We have now discovered a similar problem. Initially we thought the rot was just in one corner where the panel had been damaged but it seems it's the whole back end :( . Going to have to take out part of the side uprights and a section of the lower floor panel across the widest part at the back. Going to be a tough job as we don't have a workshop big enough to do it under cover, let's hope we have a dry autumn.
Post: # 1088Post Mike
September 23rd, 2014, 10:21 am
Btw sent you a pm on offering a cover
Cheers
Post: # 1097Post Mike
September 23rd, 2014, 8:08 pm
Nothing further last weekend as we went to a family do. Could have done with the demountable! !
Anyway painted first coat white on the jack legs. Just drying now in the workshop.
Hopefully be able or to get some time on it this coming weekend.
Post: # 1105Post zildjian
September 24th, 2014, 10:03 am
Is there an option to check the legs for corrosion inside while off camper?
Noticed it was hard work winding one of mine down yesterday, stripped it apart and found the ACME threaded bar inside completely dry & (if not rusty) exactly,
anyway wiped some grease over the thread and reassembled it again and much better.
Post: # 1106Post rubberrat
September 24th, 2014, 10:42 am
Which reminds me Zildjian, did you either find any of the black leg mech caps you thought you might have, or a supplier of a good fit, every one I have bough off ebay is the wrong size.
