Page 1654 of 1697
France; 2006 Tischer 260s Trail 19,000€
Posted: October 22nd, 2025, 5:29 pm
UK; Ford Ranger & SKarosser EC6. £36,500
Posted: October 22nd, 2025, 5:48 pm
by Gordmac
Demountable motorhome/camper and pickup for sale.
Leisure Campers Skarosser EC6L 2007, fitted to a double cab Ford Ranger Limited 3.2l Auto 2016.
Built in Arctic Sweden, the demountable unit (often described as a Tardis!) is high quality, well built and insulated to cope with the environment it is from.
There is a large double bed over the pickup cab with an opening skylight above, seating for four with a removable table which can be used to make a further double. On the left side is a two burner hob and sink with hot and cold water and a large and expandable worktop. Behind this is a decent size heated wardrobe.
On the right is a 100l Electrolux 3 way fridge with freezer compartment, large mirror on door. To the rear of this is a cubicle containing a manual flush cassette toilet with sink, mirrored cupboard and shower.
There are plenty of overhead and other storage lockers and drawers throughout. Central heating and hot water is by an Alde wet system (radiators) run on gas or mains electricity. The gas locker contains two bottles. There is a fitted side awning, separate rear porch awning and an external shower point. A ladder allows access to the roof which has a roofrack, there is a roof box that I removed as I don't need it.
The leisure battery is charged by the vehicle when the engine is running or via the built in charger when on a mains hookup. There is an internal 60l water tank and a 45l grey water tank. I am the second owner.
The Ranger has the more powerful 3.2l diesel engine (no adblue), hills are not a problem! Heated leather seats, the driver's one being electrically adjustable. Cruise control, air conditioning, heated windscreen, auto wipers and lights. 47,000 miles (will go up a little with use). Full service history.
The demountable (attached via four turnbuckles to eyes fitted to the bed) is removed via four jack legs. This gives you the versatility of a pickup and allows the demountable to be left on a site if desired. The high ground clearance and switchable 4wd allows you to go more or less anywhere with the motorhome.
I have had the demountable for seven years and the Ranger, which replaced a Hilux, three years. In that time I have had a lot of fun and visited a lot of out the way places but feel it is time for a change. I will be sorry to see it go.
Price £36,500.
Italy; Ford Ranger & Unica camper 65,000€
Posted: October 22nd, 2025, 7:41 pm
Germany ; Ford Ranger & Tischer 260sd 79,800€
Posted: October 23rd, 2025, 1:49 pm
Germany; 2024 PiCamper 20,900€
Posted: October 24th, 2025, 6:56 am
France; 1995 Shad cruiser camper 8,250€
Posted: October 24th, 2025, 7:12 am
France; Isuzu & Beka camper 47,400€
Posted: October 24th, 2025, 7:19 am
UK; Northstar 750 camper £8,950
Posted: October 24th, 2025, 10:13 am
Seller link UK
Overcab bedroom with new unused full size double mattress, roof vent, LED light and double glazed window with blind and fly screen.
Wetroom with hot / cold shower and new, unused Trobolo composting toilet. Roof vent with extractor fan and LED light. New taps, shower hose and multi-function head. Chrome shower rail and new shower curtain. I also have the original pull-down sink, and the access door is remaining if someone would prefer to reinstate a cassette toilet. There is also a full size door that can go back on.
Galley kitchen with large worktop, stainless steel sink, 4 burner hob and grill. Huge 3 way Dometic fridge freezer, utensil drawer, plenty of cupboards and storage space. Roof vent with extractor fan.
Spacious L shaped seating area with storage for the table and table leg underneath. Overhead storage lockers and insulated wardrobe to the rear. 2x Kenwood speakers, I’ve left the wiring in place for a cheap 12v bluetooth amplifier to be added if needed.
Propex Malaga E gas / 240v water heater with automatic ignition.
Propex Compact 1600w gas heater with thermostat. This is currently not working, you can hear it clicking when switched on at the thermostat but it’s not igniting. It was working previously so should be a simple fix, will try and get sorted before sale. Alternatively the outside locker lends itself very well to a diesel heater.
Fogstar 105Ah LIFePO4 battery with Bluetooth connectivity. Multiple 12v and 240v sockets.
The seating has been professionally reupholstered in a new fabric.
New heavy duty vinyl flooring.
Fiamma rear awning provides additional space.
Rear ladder and roof rack. 2x external lights with 3 separate light modes (warm white / amber / red).
Camper is 20 years old so has some dents / scuffs / marks as expected however it is absolutely solid, watertight and clean.
Comes with everything you need to get going. Waste water tank, 2x winding handles for legs, 2x Calor gas bottles, genuine Torklift mounting points and turnbuckles to secure to your pickup, 240v hook up cable and 7-pin vehicle hook-up cable for charging / rear lights.
If asking price is met I will include a full Victron solar system - 200w panel, MPPT controller with bluetooth, cables and mounts, or if preferred, a B2B charger.
Photos and video available on eBay - https://www.ebay.co.uk/itm/336248043475
France; Ford Ranger & GaZell camper 17,000€
Posted: October 25th, 2025, 8:20 am
Germany; T4 Syncro & Tischer 244 Trail 25,500€
Posted: October 25th, 2025, 6:10 pm
