Planning stage 1
Re: Planning stage 1
Post: # 13811Post derestrictor
June 20th, 2016, 8:53 pm
Good, nice sketch, but can I just say, front looks a bit featurless maybe slanted back or chamfered underneath it looks a bit van-like
Post: # 13822Post Alexd
June 21st, 2016, 8:47 am
Have you drawn your sketch with an existing manufacturer in mind,
Most of these campers are a now tried and tested shape of course and no point moving away from that at the expense of losing internal space,
As above though the nose cone looks a bit un-aerodynamic is a cone module available that could be incorporated maybe, and add a bit shape
Looking at your blog of van build-up you have some good ideas and we'll executed on the interior
Looking forward still to watching this evolve
TruckCamper
Post: # 13827Post TruckCamper
June 21st, 2016, 5:58 pm
Thanks for the comments
The sketch was a two minute thing for the panel manufacturer to give a quote.
The final design is not finished. The main reason why is that I need to find a Ranger / Navara to measure up the load bed and cab height. The info on the web is poor at best.
Andy
Post: # 13839Post derestrictor
June 22nd, 2016, 8:50 am
imagine the cab rooftop heights in relation to load beds must vary a bit, some of the campers pictured here seem quite 'close'
other owners end up sitting camper on a sheet of ply or similar to make a bit of a gap
TruckCamper
Post: # 13852Post TruckCamper
June 22nd, 2016, 5:28 pm
Thats a good point and I have noticed that in the pictures of members campers.
Looks like a trip to the dealers then
Andy
Post: # 13856Post derestrictor
June 22nd, 2016, 5:38 pm
Only mentioned it as noticed it was also a question
'should I sit camper on something to stop it sliding about'
Post: # 13864Post keeflester
June 22nd, 2016, 10:14 pm
derestrictor wrote:Only mentioned it as noticed it was also a question
If you build it to fit snug into the truck, it won't slide about. Look at the pictures on the build threads for ideas.
TruckCamper
Post: # 13875Post TruckCamper
June 23rd, 2016, 5:55 pm
Another good idea the only thing I think is what if i change the vehicle later but keep the camper.
For example if they bring out a new model with 2cm less space between the wheel arch
Andy
TruckCamper
Post: # 13893Post TruckCamper
June 24th, 2016, 5:58 pm
Project Shelved due to recent events............
