What a difference (air springs)
Madmountainman
Re: What a difference (air springs)
Post: # 7449Post Madmountainman
July 27th, 2015, 2:31 pm
Whose airbags are recommended and, how's about a pic or two of the front chassis mounting points?
Post: # 7451Post Bookend
July 27th, 2015, 3:34 pm
I fitted a MAD kit.
They only fit on the rear between the chassis and leaf spring.
Post: # 7453Post rubberrat
July 27th, 2015, 8:11 pm
Marcle for me - the cheapest that are still good quality. Dunlop bags - Around £400 ish.
Rear only, simple fitting.
Post: # 7461Post zildjian
July 28th, 2015, 7:19 am
Marcle here as well actually, yes just on back axle, pop off the bumps stops and bolt the brackets on top and bottom of bags, either some push fitting type hoses off to fill valves or in Steve's case (proper fitments)
TonyS
Post: # 7462Post TonyS
July 28th, 2015, 7:28 am
Marcle for me too.. good service, easy to fit between chassis and rear axle . . . routed inflation pipes to the gauge/valve situated on a bracket on the rear towbar.
(air springs) now with more yayage!
Post: # 7467Post zildjian
July 28th, 2015, 12:07 pm
then ideally you need to trick it out to operate remotely as much for the hell of it as you can check from outside vehicle to make sure it doesn't crush anything on inflation
Post: # 7469Post zildjian
July 28th, 2015, 2:11 pm
Well my wireless control system is installed and works beautifully (thank you) I can now remotely raise and lower truck from a suitably meaningless distance I hope this is a lesson to those of you with more pedestrian gadgets that only cut grass and then sulk in their garage if its raining my gadget works in all weathers
lamp-it
Post: # 7472Post lamp-it
July 28th, 2015, 2:39 pm
what is the other remote control for if thats included
Rob
Post: # 7474Post Bookend
July 28th, 2015, 3:47 pm
All you need is a wireless pressure gauge and your sorted.
Post: # 7475Post zildjian
July 28th, 2015, 4:11 pm
I did mess around with a regulator to constantly maintain a set pressure but I couldn't get a digital one to work without an iphone and gave up
as I don't like those,
