Air suspension
surfglobe
Air suspension
Post: # 5869Post surfglobe
May 13th, 2015, 5:05 pm
Trying to identify MAD air suspension unit for 2009 Hilux does any one have MAD bellows fitted to a hilux would really appreciate a photo, I want to fit the 8" option the units i have been supplied with dont seem to fit so I am looking for a picture to confirm whether or not they are correct thanks
Re: Air suspension
Post: # 5871Post zildjian
May 13th, 2015, 5:45 pm
Don't remember anyone fitting a Hilux with it Tony (yet)
Which bit doesn't look right though?
Bookend
Re: Air suspension
Post: # 5872Post Bookend
I should be getting a set delivered on Friday so could post some pics then
Re: Air suspension
Post: # 5873Post zildjian
May 13th, 2015, 5:57 pm
Anything like the Marcle kit, that wasn't plug'N'play either sadly,
The top brackets u bolts weren't nearly long enough and my garagist had to wel on some threaded bar to extend them long enough to reach over chassis rail enough,
It's not a load bearing component of suspension and the brackets essentially only locate the air springs in place remember
surfglobe
Re: Air suspension
Post: # 5874Post surfglobe
May 13th, 2015, 7:06 pm
Bookend wrote:I should be getting a set delivered on Friday so could post some pics then
Hi which diameter bellows did you order 6" or 8" and from which company thanks Tony
Bookend
Re: Air suspension
Post: # 5875Post Bookend
May 13th, 2015, 7:11 pm
I originally ordered the 8" but there was a supply issue as they are superseding them with the 6".
I asked for the specification of each and the 6" are well upto the job and are what they recommend.
surfglobe
Re: Air suspension
Post: # 5876Post surfglobe
May 13th, 2015, 7:26 pm
Thanks for that maybe you could post a picture when they arrive thanks
Bookend
Re: Air suspension
Post: # 5877Post Bookend
May 13th, 2015, 7:27 pm
Will do
Bookend
Re: Air suspension
Post: # 5905Post Bookend
May 15th, 2015, 11:53 am
The kit has turned up and it looks a very simple fit with everything included.
I'll try and get a pic up.
Bookend
Re: Air suspension
Post: # 5906Post Bookend
May 15th, 2015, 11:57 am
