'Adventure' though in some sales territories marketed under 'Harmar' name
Note from a previous owner
"Hi Zildjian. That was a pretty old camper 1997 build I think. The two biggest problems I had with it were the legs which had to be replaced due to rusting (the electric motors packed up too)
and the roof which leaked on two occasions - the latter so badly that the camper was a write off in the end. To be fair I did walk around on the roof a lot when loading bikes, surfboards etc but I was under the impression it should have been able to withstand that. It's a shame as even with those problems I loved owning it and it's definitely something I'd like to have again"
These excellent campers don't suffer a great number of issues,
Legs; as powered can be problematic if rain has corroded mechanism, requiring a rebuild,
Leaks; usually to rear wall, (toilet) sometimes in cab-over (at join with headboard,) once with a members' roof (though uncommon)
