Charging of leisure batteries
Posted: March 23rd, 2017, 11:22 am
Hi,
Having spent 5 days off grid in Lincolnshire last month the two new AGM leisure batteries ran very low to 20% of the available capacity. The two batteries are rated at 92 A/hr each as fitted to our recently acquired new Tischer 260.
The two solar panels put in about 4 - 6 amps when the sun was out( only one day) and 1-2 amps when cloudy.
We were running a Truma Diesel heater over night , have modern led lighting , compressor fridge set on lowest setting , 12 v TV and used the inverter once to do toast and charge e bike batteries. I have space limitations to fit bigger batteries .
We they drove 50 miles to our next off grid stop.....
The leisure batteries had only acquired a small increase in voltage from 11.2 v to 12v and up to aproximately 30% capacity as showed on the voltronic battery computer.
Compared with our previous Motorhome this was a surprise until I realised the alternator (150 amp ) is trying to charge the leisure batteries through a caravan 16 pin cable arrangement which must limit the amps being transferred compared with large hard wired charging system in a Motorhome.
Has anybody considered using Anderson connectors into the pickup tub as a separate connection to the leisure batteries to allow thicker cables to be wired in to the camper from the vehicle and improving charging rate?
Our idea of a small mobile unit on a 4x4 is to stop in remote places summer and winter and therefore the vehicle to leisure battery charging is a potential issue especially in winter.
Thanks
Tissue Box
Thanks
Tissue Box
