Simple step (Suntrekker, Hilux)
Amanda_P
Post: # 28821Post Amanda_P
July 28th, 2020, 7:36 am
I built a new and improved step for the back of my Hilux and Suntrekker:
(The embedded viewer here cuts the sides off my widescreen video, so click on where it says “YouTube” in the bottom right-hand corner to click through and watch it on YouTube’s website, where you can also see all my other videos!
You should also like, subscribe, click the ‘notify’ bell, share my stuff with all your friends, and do all that other social media stuff.
Can you have a three-paragraph parenthesis....? Well, I just did).
Re: Simple step (Suntrekker, Hilux)
Post: # 28823Post zildjian
July 28th, 2020, 8:07 pm
That is my adjustable spanner I think!
good work BTW step folds away, I like that...
Post: # 28867Post wonkywheel
August 2nd, 2020, 9:01 am
A great job with the steps. Your welding skills are better than mine :(
Amanda_P
Post: # 28888Post Amanda_P
August 4th, 2020, 8:37 am
It’s much easier with steel than aluminium!
kernowjon
Post: # 29200Post kernowjon
September 12th, 2020, 2:39 am
Hi Amanda,
You did a great job there. I moved my Suntrekker from a 2wd HiLux to a 4x4 L200 it was so high the only realistic solution (witrhin my skill sett) was to lash out and buy a 4 step Tork Lift steps from the states. Then I discovered I should also have bought Stow n Go mountings - that is not happening and I will be making my own version.
Jon
