We've seen the picture before where I think it was for sale although I can't find it now, that steel sub-frame certainly sounds a little higher than i'd have liked anyway.
I've been plodding on slowly with Suntrekker. The tasks completed are as follows:
1. Completed the panels above the windows with the rails and have now carpeted these.
2. Removed the carpet from the Luton roof ( I had planned to keep this but it was a horrible colour) and added battening and bubble wrap insulation between the battens.
3. Added a layer of army roll matt insulation on the entire roof including the Luton.
4. Added a 4mm birch ply roof panel to the main body which has been treated with Osmo Poly X oil, I've also made a panel for the Luton roof.
5. The original electrics in the Suntrekker are a bit old fashioned but work, so I've added my own circuit panel to run in parallel. I've made a control panel from plywood coated with perspex which runs across the front of the Luton but follows the original angle of the roof. This contains a circuit breaker panel, volt meter, USB power sockets, 12 v fag lighter socket a Kenwood mechless head unit and 2 5.25 coaxial speakers. This was really so I have access to these items without getting up from bed. I plan to add extra lighting and power a TV / Compressor coolbox.
6. I've removed the plastic panel from the door and replaced this with chequer plate which I plan to powder coat black. The bulging plastic panel is now on the inside of the door so the door is still double glazed but its a bit more private inside.
Hopefully I will get the main side panels carpetted and back in tomorrow.
- derestrictor
coming along well Pheonix that camper.
are there any pictures of the way you boxed in the sides please
It's looking good Clive. I really like the chequerplate door panel and the fact that you've used the window inside it. That two-part door was always a lousy bit of design - ours didn't even have the benefit of those bulging plastic double-glazed windows but was just a single sheet of glass in each half of the door. That and the aluminium frame - you could fill a bucket with the condensation each morning
Still white at the moment. Yes, that would be great if you've got any spare.zildjian wrote:Whats the outside like, would it benefit from new graphics break up that expanse of white or maybe
Cheers, I don't have any pictures but I will take some when I find my camera. The panels are bolted on and can be removed if necessary to fit the body on a standard pickup. I used a rivnut tool and stainless nuts to attach the chequer plate to ali angle and then bolted or rivetted the angle to the body with a bit of sika here and there.derestrictor wrote:coming along well Pheonix that camper.
Cheers Martin, I'm not keen on the door myself but I'm glad it doesn't have glass panels. I'm on the lookout for a better handle and some dead locks for both parts of the door as the one fitted could easily be forced and looks a bit naff. Ideally I want to change the door so its possible to open the lower part without opening the top when required, the reason for this is I plan to add some sort of rack on the back high up so I can carry a couple of bikes but I don't want to have to remove them to get in and out when I'm on the road.saDgit wrote:It's looking good Clive. I really like the chequerplate door panel and the fact that you've used the window inside it. That two-part door was always a lousy bit of design - ours didn't even have the benefit of those bulging plastic double-glazed windows but was just a single sheet of glass in each half of the door. That and the aluminium frame - you could fill a bucket with the condensation each morning
Cool idea, I like it!Phoenixsp1 wrote:I plan to add some sort of rack on the back high up so I can carry a couple of bikes but I don't want to have to remove them to get in and out when I'm on the road.
I completed a few jobs over the last week; The inside is now nearly fully re-carpeted with an extra layer of insulation underneath, i know it looks a bit grey and boring but at least it shouldn't show any dirt. I've fitted some blackout blinds at the windows with mozi nets which I prefer to the original curtains. The other job was fitting some led strip lights above the windows and I have one more to fit above the door. There is a birch ply panel which fits in the Luton roof which is missing on the photo as I have a bit of wiring to do behind the control panel so it wasn't worth putting back.
Plenty more jobs to do but I am getting down them slowly. If you're wondering what the yellow tape is for its not permanent, I was just marking some screw holes as its easy to lose them in the carpet.
Wow! That's looking really good Clive. Grey and boring is good - as you say, it hides the muck. As far as I can remember in our Suntrekker when we slid the bed out it came some way across the windows and would have fouled against those really nice blind/mozi net cassettes. I guess your hanging system avoids that huh?
In theory yes but at the moment the clearance is a bit tight, only about 15mm each side, so you have to be pretty careful when you slide the bed out. This is not always the case if I've had a couple of beers. I cut the original steel support down by a couple of inches each end and bolted on the door strikers from a Passat as they looked nice stainless and were free. (You can see them in the pic at either end of the steel support) I think I'm going to cut the steel down the extra 2 inches either side so it's flush with the ply and then bolt the loops through the front of the steel support. I still need to have a method to lock the bed when it's slid out, I think I'll use a couple of door bolts that go into the side of the board, it needs to stop the board twisting otherwise the blinds would get damaged, hopefully it will work. I still need to make some sort of headboard or trim the original one at some point.saDgit wrote:As far as I can remember in our Suntrekker when we slid the bed out it came some way across the windows and would have fouled against those really nice blind/mozi net cassettes. I guess your hanging system avoids that huh?
