Hi from Poppi in Devon
Welcome, how can we help ?
Poppi
Re: Hi from Poppi in Devon
Post: # 3592Post Poppi
January 26th, 2015, 10:19 pm
Ok I have sent a pic of Daisy and her inside too :)
I am not sure if it can actually be demounted easily as it is bolted to the frame of pick up and no bed has been left in place so probably not.
I sometimes have my skye terrier with me and have a 17yr old son who is off to uni in September.
I have a vango tent canopy which i attach to rear of Daisy by the awning channel and intend making a sun canopy at some point for the side awning rail.
I don't think i will bother with attaching solar panel to roof but keep it mobile . I only need it to keep the leisure battery topped up as i don't have a split charge unit and like to keep things simple.
Poppi
Post: # 3597Post zildjian
January 26th, 2015, 10:25 pm
well in that case you might get away with a suitcase arrangement,
literally in a suitcase you fold it open and point it skyward, hook it up directly with crocodile clips to battery then just put it away again after,
can you reach LB easily?
Post: # 3601Post derestrictor
January 26th, 2015, 10:47 pm
Looks cosy Poppi, whats the heating like?
Poppi
Post: # 3641Post Poppi
January 27th, 2015, 3:01 pm
zildjian thats is what i thought and bought a small suitcase panel and each time i came home plugged it in on drive but it didn't top up battery but obviously havent tried it on a good battery as mine needs replacing.
Derestrictor I don't have any heating in her but through winter when on drive i plug her into house and have a tube heater inside just to protect fabrics and furnishings from damp and mould really.
She is my only vehicle so is used regularly.
Poppi
Post: # 3654Post zildjian
January 27th, 2015, 7:29 pm
sensible to add a cheap heater over worst weather, an oil filled rad costs pennies daily to leave on low and its best Poppi to not let a leisure battery go flat either, they don't like it
and in my case its not only the expense, its a devil of a job to swap it too
Post: # 3658Post rubberrat
January 27th, 2015, 8:05 pm
Is yours a pain to swap because of that bulkhead on the SKarosser? I lopped 15mm off the bottom with a jigsaw, remove water pipe too (if tank empty!) and out it slides.
Post: # 3659Post zildjian
January 27th, 2015, 8:11 pm
There's not room to lift it out one end first in any way, a seat base has to come out and dismantle that step that peaky mended on his too
Post: # 3663Post rubberrat
January 27th, 2015, 8:38 pm
I'll try to photograph mine tomorrow to see what is different.
Post: # 3685Post zildjian
January 28th, 2015, 2:12 pm
Poppi, I had a look at your FB page, https://www.facebook.com/PoppisUpholstery?fref=ts
would you like to put a few of your images in here and a note on what you can do ?
think it might be of interest to others here,
let me know and we'll start a thread on it and Peaky can add you to our links page too
Poppi
Post: # 3819Post Poppi
February 1st, 2015, 5:02 pm
zildjian wrote:Poppi, I had a look at your FB page, https://www.facebook.com/PoppisUpholstery?fref=ts
Oh wow thank you zildjian that would be great ! I will email a few that i feel maybe relevant :)
Poppi
