Storing camper on pallets etc
earthman
Post: # 16071Post earthman
November 23rd, 2016, 12:26 pm
I've seen a fair few pictures of say a stack of pallets being used underneath a dismounted camper, does anyone on here actually practice this every time they lay up their camper for the Winter for example?
OK, I know that when you dismount on a campsite, you are relying on just the four legs to take the weight of the unit and the occupants inside so why the need for the extra support when back home? Are you thinking that it takes a bit of pressure off the internal mechanism of those jack legs and the four body/shell mounting points of the camper??
I assumed that the entire floor of a camper would actually rest on the whole bed of a truck but in the case of a Tischer, it's actually on four small blocks of wood, so the unit were designed to be supported solely by those 4 points whilst sitting on a truck/other elevated surface I guess.
Re: Storing camper on pallets etc
Post: # 16072Post zildjian
November 23rd, 2016, 6:42 pm
'On holiday' I don't go inside camper without either;
dropped down low on legs so you can step into it from ground without steps
or
with truck parked beneath it after a day out sort of thing....
Over winter some people drop them onto something solid together with legs on floor as extra steadies as in high windy days its not unknown for ours as well as caravans to come a cropper (but rare)
earlier older campers had suspect floors and it wasn't encouraged to go walking about in them but not an issue on modern construction
Lost in the wilds
Post: # 16096Post Lost in the wilds
November 25th, 2016, 4:37 pm
I'm sure the legs on our Tischer are more than up to the job of supporting the weight. However, she rocks when the wind blows.
I used to have nightmares.......now I have a wooden cradle. I sleep better.
We already had most of the wood so cost was minimal. Chain saw, screws, threaded rod, nuts, washers and a day's work got it finished.
If Zildjian reminds me how, and our steam-driven internet connection permits, I'll post a photo.
Chris
Imageupload a gif
Post: # 16105Post derestrictor
November 26th, 2016, 5:49 pm
That looks belt & Braces approach
earthman
Post: # 16541Post earthman
January 11th, 2017, 11:08 am
This is what I've designed/fabricated from mostly scrap pieces of metal that I had left over from another project. :)
I decided to make it somewhat foldable, easy to move/store out of the way when need be. :)
Post: # 16547Post Mike
January 11th, 2017, 6:59 pm
Very neat
earthman
Post: # 16550Post earthman
January 11th, 2017, 7:59 pm
Mike wrote:Very neat
Thanks. :)
Post: # 16569Post derestrictor
January 13th, 2017, 8:08 pm
Nice neat job Earthman you should market them on here :?
Post: # 16570Post sabconsulting
January 13th, 2017, 9:14 pm
I have an old black and decker workmate and another similar folding workbench. I sit the camper on those and the 4 jacks when off the truck. I'm certainly not lowering it all the way down since I've got manual jacks.
earthman
Post: # 16602Post earthman
January 17th, 2017, 6:02 pm
derestrictor wrote:Nice neat job Earthman you should market them on here :?
Thanks,.....I've pretty much run out of steel stock right now but if anyone is interested in having one made, I'll see what I can do. :)
