Buying used SKarosser print this off...
Post: # 13111Post zildjian
May 11th, 2016, 9:42 pm
When buying any used camper we always recommend taking along a damp meter these are cheaply available from Ebay and simple to use and can save you a lot of money and act as a bargaining tool.£8.79
Swedish campers exported all over Western Europe
marketed in Germany as 'Nordstar' or lately 'Northern Lights
France as 'Easy camper'
UK as 'NSR' or 'Easy camper'
recently re-imorts into UK started after a lapse of eight years due to a direct sea crossing between NE UK>Sweden ceased
to date and unless badly treated pretty bomb-proof in fact, little spring that retracts window blind can do with a re-tension every few years, fridge door latch snapped (that was me) what else,,, oh thats about it
Alexd
Contact:
Re: Buying used Skarosser print this off...
Post: # 13157Post Alexd
May 15th, 2016, 5:43 pm
http://overland-live.blogspot.co.uk/201 ... osser.html
interesting if a bit out of date perhaps
Something to report !
Post: # 13525Post zildjian
June 6th, 2016, 8:09 pm
'Kitchen' window stay,
stopped holding window open, removed it and looked,
In the picture below my thumb is a little spring clip in grey plastic, remove that to reveal a tiny spring with a ball bearing beneath it that bears down onto the sliding ram inside and locates in three shallow holes which holds window
closed>open>open more>fully open,
a spring out of retractable pen, tiny bead from some a broken bracelet and its fixed
saDgit
Re: Something to report !
Post: # 13526Post saDgit
June 6th, 2016, 8:27 pm
zildjian wrote:'Kitchen' window stay,
A small cable tie around the grey plastic spring clip stops it from happening again.
Heating stopped working ;check this
Post: # 16714Post zildjian
January 27th, 2017, 2:30 pm
Had an Alde engineer out today to service the system as I'd never had it looked at or seen anything from previous owner about it either,
heating had stopped working although boiler produced plenty of hot water from tap.
As he opened the hatch behind boiler He noticed some damp on rubber seal around door and on inspection found a pinhole in this rubber elbow which almost immediately split as He looked at it
Now I think about it, there HAD been a damp spot on floor in that corner though I'd though it was rain off the roof,
Engineer is coming back in a week with rubber elbow, some service parts and refill with correct glycol mix I'll let you know bill
Re: Buying used SKarosser print this off...
Post: # 17489Post zildjian
April 15th, 2017, 3:44 pm
replace perished hose, heater service around 180 quid
Post: # 18873Post zildjian
August 11th, 2017, 6:05 pm
1900-542 (Part #) for Alde3000 Boiler
was losing a 'cupfull' of glycol based fluid each day due to this 'bottle vent' having gone wrong
these Alde boilers don't require routine maintenance but like a check over & service every few years
Post: # 20455Post zildjian
January 6th, 2018, 7:04 pm
And this from a member whose lights dimmed one night.....
Post: # 21962Post zildjian
May 21st, 2018, 7:00 pm
Little thing this time;
Shower head, discovered a small puddle of water in shower tray this morning, imagined it might be the Thetford toilet flush tank (not quite sure why) and had look but saw nothing untoward,
finally tracked a small water seep from shower head trigger thing,
only ever tried tried shower once in all the time I've owned it and gave up immediately as it meant refilling fresh water tank!
and the control beside sink I always imagined to be a tap (and so probably OFF) is in fact likely a temperature control,
meaning shower is permanently under pressure.
Next week when I get back I'll either remove and cap it off depending on access, or repair or replace shower head although we never use it
Post: # 21963Post mjb666
May 21st, 2018, 7:25 pm
A shower & loo was right at the top of my want list when i started looking for a De-mountable 8 years ago, not really sure why but we decided we must have this set-up.
All i ended up with is a room with neither, i suppose i could put a porta loo in there but we haven't. It's got a sliding door and we use it to store everything that we take away.
If we ever upgrade, we've decided that it isn't a deal killer.
Do other owner's use there's a lot?
