Meki saying ey up
Welcome, how can we help ?
Meki
Re: Meki saying ey up
Post: # 6776Post Meki
June 30th, 2015, 9:12 pm
From this:
To this:
Post: # 6810Post derestrictor
July 1st, 2015, 6:00 pm
good how replacing little bits even like that can alter appearances so quickly, what other bits have been done?
Meki
Post: # 6863Post Meki
July 3rd, 2015, 6:57 pm
derestrictor wrote:good how replacing little bits even like that can alter appearances so quickly, what other bits have been done?
Today we purchased plastic panels to reline the shabby and worn old walls, very light weight and very good value, that's tomorrow's job, as is, replacing the extremely rusty piano hinge holding the battery compartment door with stainless steel
Bookend
Post: # 6864Post Bookend
July 3rd, 2015, 7:12 pm
Saw you this afternoon on the A61 crossing the A38.
I had to abandon the M1 and cut through clay ✖ :roll:
Meki
Post: # 6869Post Meki
July 3rd, 2015, 9:00 pm
Bookend wrote:Saw you this afternoon on the A61 crossing the A38.
Twas indeed us, we saw a sufficiency of mk6s today, so we probably did see you too, we went to collect the light weight shower walling for the Demountable from Chesterfield
Post: # 6875Post zildjian
July 4th, 2015, 6:42 am
So what else is on your list there then? You were saying you expecting to take it with you presently I think so must be doing well
Meki
Post: # 6880Post Meki
July 4th, 2015, 2:13 pm
zildjian wrote:So what else is on your list there then? You were saying you expecting to take it with you presently I think so must be doing well
Water proof vinyl flooring and walling in the bathroom area, under that is a very thin foil and foam membrane
The bike rack should be back from the zinc and powered coating place today
Loads more stainless screws and bolts to replace the rusty old stuff
Meki
Post: # 6919Post Meki
July 5th, 2015, 8:35 pm
BBB bike rack frame came back from The sprayers, the quality of finish is outstanding, blasted, Zinca coated and powered coated, the finish is so thick, it feels tactile and super smooth, you just have to keep stroking it.
As was:
As is:
Of course all the fittings are now in Stainless
