postimage experiment
New link to this brilliant wealth of knowledge on the subject
Postby astartosteerby » October 20th, 2015, 8:03 pm
post image online
Experimenting with the transfer of an image from my PC to here via postimage.org.
Doesn't look very successful so far. If a picture means a thousand words, I've got as far as one of the corners in a jigsaw puzzle.
astartosteerby
Re: postimage experiment
Postby astartosteerby » October 20th, 2015, 8:04 pm
Wow, it has come out alright. Was a load of geekgabble before.
astartosteerby
Postby zildjian » October 20th, 2015, 8:27 pm
Obviously kudos
Postby zildjian » October 20th, 2015, 8:29 pm
There are other 'image hosting' sites just google, some charge, some demand you register, but all work much the same way and honestly after a couple of pics you'll just fly through it with practise
Postby derestrictor » October 20th, 2015, 9:21 pm
This one is a bit simpler http://tinypic.com/
Postby zildjian » October 21st, 2015, 8:21 am
Yep, tinypics another one, I use that as well sometimes, no membership but they ask you sometimes to prove you are human thats all
Postby derestrictor » October 21st, 2015, 8:47 pm
(caution) postimage is quite easy to use but does cut off the righ hand side of the pictures here
where tinypic doesnt
Postby lamp-it » October 23rd, 2015, 3:11 pm
practise is needed to select the right code on postimage then its fine, but can be a bit daunting to look at
Rob
lamp-it
Return to stuff about demountables
Who is online
Users browsing this forum: No registered users and 2 guests
