taking the hard top off
Using hoist for first time
All tied up bit of an angle but easier to lift off than by hand
Re: taking the hard top off
Mine's propped up in the garage just now,
I probably should have left it warehoused at work I don't need it until year end now after all, but this is becoming a thing with you lot
(and yes I blame Mark)
Pfft! ^
Mike, would the roof rails be strong enough to lift with meatier plates on the underside?
I do the exact same thing.
Doesn't it clutter up the place though?
I just haven't got the room to work around it unfortunately
The hard top comes off and on every time I mount up. It comes off the truck and sits on the trailer my demountable usually sits on. It only adds about 20mins to the process.
Hi Mark well im not sure, they are designed to have weight bearing down rather than pulling. The hardtop is metal so quite heavy, thats why I felt better to wrap round under neath.rubberrat wrote:Pfft! ^
Similar setup to ours for the L200... no hardtop on the Amarok currently - luckily as the carport needs raising first..
So Chris, a variety of different methods here all of which positively scream Health and safety, but as I say if you can slide it off over tailgate onto something roughly the same height as truck, that's easiest and safest
