Northstar 700 on Hilux double cab
Wuzz
Post: # 28840Post Wuzz
July 30th, 2020, 8:41 pm
Hi All,
Anyone out there with some advice on fixing down a Northstar 700 demountable without the cleats fixed through the bodywork? Have thought of using some cut down acro props bolted/welded to the chassis which would enable the extensions that protrude to be taken out when demountable not in use. Any cunning plans gratefully appreciated.
Cheers
Rob
Re: Northstar 700 on Hilux double cab
Post: # 28841Post zildjian
July 30th, 2020, 9:59 pm
You aren't far off with your idea, Northstar owners have been less than impressed with their fitting system and while it works not everyone wants holes in the bodywork after all, belly bars like this (and yours) crop up;
https://www.rv.net/forum/index.cfm/fuse ... 498897.cfm
Wuzz
Post: # 28846Post Wuzz
July 31st, 2020, 7:20 am
Thanks for the pic. Does anyone know if Torklift has a UK disributor?
Post: # 28850Post zildjian
July 31st, 2020, 10:27 am
You might try ; http://www.niche-marketing.net/
they are the UK importers for Northstar campers
Post: # 28865Post derestrictor
August 1st, 2020, 9:21 pm
north star are now the only manufacturer still relying on those chrome dome button things in the side of your pickup :shock:
Wuzz
Post: # 30172Post Wuzz
March 14th, 2021, 4:08 pm
Hi
Further to my questions last year about getting my Northstar 700 secured onto my Hilux I went and had some brackets fabricated having made cardboard models for a custom fit, rear ones easily bolted on and front ones to be welded on this week! Pics of result at the weekend.They cost me £180.00.
Post: # 30173Post derestrictor
March 14th, 2021, 4:52 pm
they should be just the job, bet if you had ordered those from Torklift in america they would have been as much in tax duty
as cost
Wuzz
Post: # 30313Post Wuzz
April 6th, 2021, 7:05 pm
Finally ready for the off !
Post: # 30314Post zildjian
April 6th, 2021, 7:35 pm
That's it!
they look just the job & both pulling <forward just a little too so the orange strap should be belt & braces
but can't do any harm,
Where do you plan going first :)
Wuzz
Post: # 30318Post Wuzz
April 7th, 2021, 4:16 pm
Probably a car park not too far away to test things out! After that Devon and Cornwall first as they're not far away. Cheers
