VW Amorak rear mounting eye bolt locations
gone bushy
Post: # 23808Post gone bushy
October 9th, 2018, 10:26 am
Hi All,
Picking up a Tischer 230s next month from Golum and just sorting out the truck modifications. Its a VW Amorak and happy with everything just could do with an accurate location of the rear eye bolts and would very much welcome a photo if possible,
Cheers
Ed
Re: VW Amorak rear mounting eye bolt locations
Post: # 23809Post zildjian
October 9th, 2018, 2:21 pm
VW owners still quite scarce amongst us but I know Chris & Carol are Tischer owners too so I'll contact them as well
Lost in the wilds
Post: # 23811Post Lost in the wilds
October 9th, 2018, 2:45 pm
Chris will take some pics and post them as soon as he's cleaned the debris out of the truck bed (been collecting logs).
Carol
gone bushy
Post: # 23812Post gone bushy
October 9th, 2018, 4:07 pm
Thanks for the responses, I appreciate it very much and look forward to the photos.
Post: # 23815Post mjb666
October 9th, 2018, 7:14 pm
Can i ask what the upright wood/fibreglass and metal 'V' assembly is for at the far end of the truck bed going upwards. Is it some sort of bespoke additional fixing kit for the Tischer De-mountable?
Mike.
FinAde
Post: # 23817Post FinAde
October 9th, 2018, 8:01 pm
We have an Amarok and a 230S. Golum fitted the eye bolts. I’ll take a photo tomorrow and post for your information.
Tischer 230
VW Amarok
Post: # 23818Post mjb666
October 9th, 2018, 9:04 pm
Hi Chris
Sorry, another question. Has the offside wheel arch part of the plastic bed liner been cut away because it was broken or is the Tischer 230S a really tight fit once fitted?
Mike.
Lost in the wilds
Post: # 23822Post Lost in the wilds
October 10th, 2018, 8:33 am
At the front of the bed there is a horizontal aluminium bar (at floor level) which acts as a spacer and bottom support for the two wooden verticals (to which I attached some coconut matting as cushioning).
The verticals act as stops - when we load the Tischer we get the front end right up against the stops and then adjust it laterally.
Nothing has been cut away from the liner - I think you are looking at a shadow - pics taken on a bright, sunny afternoon (typical West Wales weather!).
Without wishing to make the proverbial egg-sucking attempt I presume you realise that the eye bolts are attached to the chassis and not just to the tub.
I suspect photos may not be enough for someone attempting this for the first time. We're open to visitors (we're near Carmarthen) and may be in Somerset/Devon soon.
Chris
gone bushy
Post: # 23823Post gone bushy
October 10th, 2018, 9:13 am
Thanks Chris, well aware that they attach through to the chassis and support ✖ member, cheers :)
