Page 2 of 2
Re: Wheel size change = Altered speedo readings?
Posted: January 12th, 2017, 7:56 am
by Big Jim
I make the difference 12.7%
Normally 2.5% is the max recommendation .
If your speedo now reads 50 you are now doing 56 , assuming that your speedo is accurate . They normally read a little more than the actual speed so if your speedo says 50 I would guess you are actually doing 53ish . Check it with a sat nav .
Jim
Posted: January 12th, 2017, 6:30 pm
by sabconsulting
earthman wrote:Another option maybe, find a place on the dash to mount a Scangauge or similar, apart from giving a speed readout there's other features, it can read/clear some fault codes too,.....all assuming that the vehicle has an OBD2 port in the first place.
https://www.scangauge.com/
Do those electronic ODBII gauges allow you to apply a factor to the speed reading to cater for differing final drive ratio / tyre diameter?
Posted: January 13th, 2017, 12:18 pm
by earthman
sabconsulting wrote:earthman wrote:Another option maybe, find a place on the dash to mount a Scangauge or similar, apart from giving a speed readout there's other features, it can read/clear some fault codes too,.....all assuming that the vehicle has an OBD2 port in the first place.
Ah, that's a good question, I never thought of that.
I don't recall ever seeing such settings, I have no idea on how it actually works 'out of the box' considering that it's plug & play, can be used on many different vehicles which would have many different wheel/tyre combinations.
I used mine on a Smart car and now a Dmax, the speed reading it gives is the same or within 1mph of the Sat Navs I've used at the time too.
Posted: January 13th, 2017, 3:21 pm
by Gary W
Scangauge yes, either by adding/subtracting theoretical difference in circumference as a percentage, or by synchronising with GPS speed.
Posted: January 18th, 2017, 1:26 pm
Another vote for the phone app. I have an outdated spare Samsung Y that I use every day as a speedo - no sim in it but have DiGiHUD downloaded.
Mainly because it has a very large digital readout that I can see without taking my eyes off the road.
Handy now that police will be looking for a potential revenue stream for being 1mph over. Good luck if you can hold + or - 1 mph with an analogue speedo over any distance without staring at the needle rather than the road andits hazards ahead.
I can't so the digi HUD it is.
Posted: January 18th, 2017, 7:00 pm
by sabconsulting
rubberrat wrote:Another vote for the phone app. I have an outdated spare Samsung Y that I use every day as a speedo - no sim in it but have DiGiHUD downloaded.
Does that use the phone's GPS for speed measurement?
