- wonkywheel
Zildjian, still quite a bit to do yet before I make the move but I am a lot more optimistic now it's coming together
My to-do list is still quite long before I need to expose it to the general public's gaze I'm afraid. I need to clear a space in the "Car Park" for it.
I might even strip "Lightning" (teardrop) down for all the useful bits to enable me to stand the chassis on end up a corner somewhere make space, but I am hedging my bets at the moment.
I need to find a garden gate type yale lock to fit on the access gates and do a little fence repairing.
Fitting tie-down eyes to the truck.
Pay more attention to the lifting jacks. I have quite a few bits towards them, leadscrews, nuts, bevel gears, and bearings but need bushes and a final design Also fixing the jacks to the camper. Do you leave in position? pack away? or fold up? .....undecided.
Also, can you get insurance for a home build? I even had some toerag try to prize the ball hitch lock of "Lightning"
- wonkywheel
A bit little bit more today.
I did a random test on the strength of one of the 2" x 1" spars. I hit it with a dumb object,
The spar stood up quite well but I don't remember putting the stars in there
You have seen hard sided demountables, Pop top demountables. But I could have the only ....
CAMO FLOP TOP DEMOUNTABLE
It helps in making it a little less obvious over the fence height and makes a fair workshop(if you look where you are going)
I think I will drag the welding trolley up and weld some or the verticles together while they are in place. I still intend to dismantle it to move up the garden (providing I dont get carried away with the welding)
Nice work!
I would like to award you something for camper-inflicted-injury but that award is safely under my own belt
I'd rather not talk about it OK
- wonkywheel
Oh ....go on
No, while I accept newbies might look at people like me for the reassurance and certainty of experience
I'm really not that guy TBH, and I'm not telling other than the fact it was an insurance claim
- wonkywheel
OK, we will leave it at that.
Just remember the demountable is on the back next time
- wonkywheel
Weather looks to be improving
Stamina after a lazy week in Devon improved too.Back out to the workshop( back garden ) to resume work
The camo tarpaulin has suffered badly with all the wind and has holes ripped through where the corners cut their way through.
On the stamina front....good news.
I have enlisted the help of my grandson, who only goes college 3 days a week So given good weather on either Friday or Monday and a little financial inducement the build might move on a bit quicker.
The plan is he does all the weld prep work and lugging about, which I find energy sapping, and I'll just stick it together.
I have already cut and repositioned the cab over bed frame ready to weld up. With this done I can cut the fiberglass sheet for the bottom. I have cut extra bracing for the rear panel. I just need to replace a couple of the corner verticals with some of the 2x1 heavy section in preparation for the leg fixing points.
I have ordered oilite bushes to complement the thrust bearing for the legs, even though I haven't finalized the design yet. I am hoping some inspiration come with them
Picture and design details to follow(I hope )
The better weather might help now hopefully, are you aiming to make the legs all fixed in position or removable to stow somewhere,
They are out of danger stowed of course
- wonkywheel
Initially, I think the legs will be fixed in position.
I think they are a little over-engineered and will be strong enough for all occasions.
I might bolt them through from the inside then there is no chance of them getting pilfered.
The only removable piece will be the bottom adjustable section and foot with a lock pin. This is necessary as I intend using 500mm lead screws for the lifting section.
Hinged fold up ones would be nice and tidy but might be a little testing to achieve. The next time I get the chop saw out I'll cut a few test pieces and try to fit the oilite bushes, thrust bearing, leadscrew an nut together to formulate a working design
I had fixed legs on my Nortstar . They hung quite low and wide out when travelling and I was always bothered about catching one on a tree stump or high verge or something.
